WeBoost Mounting on Hunter Compact / Campster - Fiberglass RV
Old 11-22-2020, 10:15 AM   #1
Dax
Trailer: Havasu
Question WeBoost Mounting on Hunter Compact / Campster
Hi Everyone! I'm hoping to purchase a Campster soon and am wondering how you mount a WeBoost antenna? I haven't gotten to see one of these campers in person yet, but seeing as how it's fiberglass, doesn't look like the magnetic option will work. It doesn't seem to have an attachment points to attach an antenna safely so what's your solution? I was thinking maybe using epoxy to attach to the top?
Also, what model did you get? I need the most boost that can work while in motion. Since they are so small thinking of Drive Reach or Drive Reach OTR
Dax is offline   Reply With Quote
Old 11-22-2020, 11:12 AM   #2
I looked up the antenna/booster. I think your best option for a Campster or most any fiberglass trailer will be a pole mounted to either the rear bumper or behind the hitch in front. I'm not sure whether this antenna requires a ground plane, but the frame of the trailer can serve that purpose. They mention attaching it to a rear ladder. A pole should work as a substitute.
Thats the approach I've taken with my ham radio antennas.
If you really wanted to use a mag mount, set up the booster in your tow vehicle and set the inside antenna where you can pick it up from inside the trailer. You would have to figure out how to power it.
Dave Fish is offline   Reply With Quote
Old 11-22-2020, 11:25 AM   #3
Trailer: Bigfoot Silver Cloud
We have our WeBoost RV model mounted on an extendable pole that we bungee to our awning arm when camped. I raise it to about 12 feet, which is the limit to our cable running into the trailer. For use when on the road, Iíve never tried because our smart phones seem to work fine in mobile hotspot mode if needed.
Old 11-22-2020, 01:42 PM   #4
Illinois
We use the Drive Reach on our fiberglass Casita. Outside antenna comes with a magnetic plate with adhesive for non metallic surfaces. Seems to work fine on the fiberglass. Inside antenna placement is tricky since there is no metal roof to prevent interference between inside and outside antennas. Just remember if you have no phone signal, there is nothing to boost!
mike c patton is offline   Reply With Quote
Old 11-22-2020, 02:34 PM   #5
Dax
Trailer: Havasu
got it. This is super helpful!
Old 04-03-2021, 02:32 PM   #6
Trailer: casita freedom
do you have pictures on this install?
echarteris is offline   Reply With Quote
Old 04-03-2021, 02:33 PM   #7
so did you drill the metal plate to the side of the fiberglass trailer? or do you have a pole you use? can you post pictures?
Old 04-03-2021, 02:51 PM   #8
where does the cable enter the casita?
Old 04-03-2021, 02:52 PM   #9
how did you and where does the outside cable enter into the trailer?
campster
Mislabeled Compact[jr], Hunter, TrailsWest Campster on ebay Kenny H Classified Archives 5 05-26-2009 08:55 PM
Why not a new Compact/Campster/Hunter type? Bobbie Mayer General Chat 0 08-26-2008 11:19 PM
Hunter Compact or trailswest campster Kent I Care and Feeding of Molded Fiberglass Trailers 3 06-20-2007 09:14 PM
Hunter Compact or trailswest campster Kent I General Chat 0 01-01-1970 12:00 AM
