My charge controller seems fussy. It specifies the order in which to connect and disconnect it from the system. To connect:
battery first, then
solar panel, then the load. To disconnect: reverse.
Sometimes I have disconnected my
solar panel only without disconnecting the load. Sometimes that is OK -- other times, it results in loss of power.
(My panel is not permanently affixed to the old 17'
Boler, so when we travel I put it inside).
I am thinking of putting an interrupt switch on the load wire that runs out of the controller so that I can just toggle a switch to remove the load from the controller without pulling any wires. Then I can disconnect the panel. And do the reverse when firing it back up.
Would a 30 Amp rocker switch be able to handle the job? I was planning to put it on the negative wire.
