Wire routing near Bathroom? 2016 13' Scamp - Fiberglass RV
Old 02-02-2023, 05:20 PM   #1
WI
Hello,
I'm trying to find out where the wires around the bathroom are located.
I need to run a wire from the charger to the battery (temperature sensor).
If they aren't obviously accessible, have any of you successfully fished wires routed past the bathroom?
Thank you,
Catya
2013 13' Scamp.
Catya is offline   Reply With Quote
Old 02-03-2023, 12:30 PM   #2
WI
ooops: 2016 13' Scamp.
Old 02-03-2023, 08:36 PM   #3
The wires come into the trailer near the closet floor. Then they go between the bath liner and shell to the bottom of the kitchen cabinet. Try a wire snake. Or drill a hole in the floor on the outside the frame rail and attach the wire to the frame rail with straps or use clamps and short screws and attach your wires to the bottom of the floor. The second would be the easiest way to get to the battery box.
Old 02-03-2023, 09:13 PM   #4
WI
Thank you, Eddie.
Just be be clear, they go around the outer perimeter of the bathroom towards the front, not under, along the door, right?
Old 02-04-2023, 08:19 AM   #5
yes.
Bathroom Sink Water & Drain Line Routing 19' Scamp Tcjmiami Plumbing | Systems and Fixtures 5 09-15-2022 01:19 PM
Brake Wire Routing courtney Electrical | Charging, Systems, Solar and Generators 4 08-06-2021 02:01 PM
Scamp with bathroom water line routing Riomcoupe Plumbing | Systems and Fixtures 3 06-05-2020 06:40 PM
yellow wire/brown wire deryk Electrical | Charging, Systems, Solar and Generators 24 01-01-2013 06:34 PM
Wire Routing Loren G. Hedahl Problem Solving | Owners Helping Owners 8 02-20-2006 12:47 PM
Copyright ©2000 - 2023, vBulletin Solutions Inc.
