Wiring 7 pin connector troubke - Fiberglass RV
Old 07-24-2022, 12:09 PM   #1
Trailer: Jayco
Trying to add a 7 pin female connector on 96 T100.
The brake lights and turn signals seem to go on the same pin connection ( left side brake/turn pin and right side brake/turn pin).
All trailer lights and truck lights work great when brake lights wire not connected to pin. When I connect truck brake light wire to same pin as left turn wire, the current feeds back to turn lights on both truck and trailer.
How do I prevent current crossover/ feedback when both pulling vehicle’s brake and turn light wires are connected to same female plug pin?
Kevin in Meeker is offline   Reply With Quote
Old 07-24-2022, 01:31 PM   #2
Jon Vermilye's Avatar
Trailer: Escape 17 ft Plan B
If your tow vehicle has separate turn & stop lights, one of these will solve the problem. You will have to connect the output to a 7 pin connector rather than the 4 pin it comes with.
Old 07-24-2022, 01:50 PM   #3
etrailer.com may have a converter and wiring harness specifically to fit your vehicle, plugs in to harness in your vehicle. They have good support / installation videos
Old 07-24-2022, 02:12 PM   #4
Trailer: Jayco
Jon,
Tow vehicle (1996 Toyota T100). Has separate turn and stop lights. Trailer (2022 Jayco) came with 7 pin male plug.
Trailer uses same lights for turn and stop. Directions for custom wiring 7 pin female hook up to truck indicate that left turn light wire and left brake light wire go to same female pin attachment ( ditto for right side turn and brake wires). Both brake lights and turn lights work on tuck and trailer when only turn OR brake is wired to pin. When both are wired to same pin, current crosses over between brake lights and turn lights.
I don’t know how to attach both brake light and turn light wires to same pin hitch without creating the electrical cross over???
Old 07-24-2022, 02:42 PM   #5
Name: You can't call me Al
Trailer: SOLD: 1977 Scamp 13'
Massachusetts
You need a converter to wire this and have everything work.
Here's a page from eTrailer to get you started.
https://www.etrailer.com/question-32884.html
I would either search on their site or give them a call.
Their technicians have always been very knowledgeable when I've called them or done the internet/web chat thing.
AlanKilian is offline   Reply With Quote
Old 07-24-2022, 09:33 PM   #6
Trailer: Jayco
Thanks Alan
Thank you Alan. A mechanic buddy of mine just told me the same thing. I researched this quite a bit on line before joining this forum, and never saw mention of a converter. Hopefully this thread helps the next person. Too bad the 7 pin product instructions didn’t mention the potential need for a converter. Mystery resolved.
7-pin connector wiring. Unusual problem getting running lights working. zack sc Problem Solving | Owners Helping Owners 21 05-04-2020 07:41 AM
Scamp wiring connector pin-out? hobofoto Towing, Hitching, Axles and Running Gear 18 05-13-2015 12:14 PM
boler 7 pin connector troubles al gilliland Problem Solving | Owners Helping Owners 6 04-24-2007 01:02 PM
7 pin connector Dan Simon Problem Solving | Owners Helping Owners 2 08-05-2006 09:54 PM
Wiring 04 Highlander to 7 pin Bargman connector Gary Little Towing, Hitching, Axles and Running Gear 18 06-02-2006 07:46 PM
