Originally Posted by Cyndivg11
I was going to bring my 84 fiberstream to an RV dealer to have the water pump and water heater looked at- and I know they will probably charge me an arm and a leg for replacement. How do I know if they need replaced?
I still use the original Water Heater in my '78
Fiber Stream because of its old fashioned simplicity. The gas burner works well, but the electric element doesn't seem to work... and I'm OK with that.
My original pump only supplied low pressure; the water didn't flow but merely trickled, and the pump noise could wake the dead.
I was very happy with the results of replacing it. Good water pressure and near silent operation.
OLD NEW
Your '84 probably has a
Furnace where my Water Pump is located; but setting it up beside the tank instead of between the tank and water heater like mine is doable.
