Adding a water heater - Fiberglass RV
Old 05-13-2016, 08:08 PM   #1
Iowa
I've got a 6 gallon atwood water heater and i'm looking at putting it into my Scamp 16. I'm trying to decide the best location for the water heater.
Currently I'm thinking under the drivers side rear dinette bench right next to the fridge as the fresh water tank and plumbing fill up the other bench and we have an external hand held shower under the sink along with the breaker box. My other reason for considering this location is the ease of tapping into the gas as the fridge and furnace already have gas hook ups close by.
jjorgensen is offline   Reply With Quote
Old 05-13-2016, 10:42 PM   #2
David B.'s Avatar
That's where I installed one in our 13' Scamp, and it worked out great. I removed the bench for the installation, then replaced it after. I did have to "sandwich" a backer plate made of wood between the trailer skin and the water heater box. It was easy placing a "T" in the cold water line to feed the heater and another one in the copper propane line at the furnace feed. Best of luck.
Dave & Paula
Old 05-13-2016, 10:59 PM   #3
When you tap into the propane line you should use a flaring tool in the copper line. Use of compression fittings is not legal with propane.
Old 05-14-2016, 09:17 AM   #4
Paul O.'s Avatar
The water heater is pretty heavy, not by itself, but because of the 6 Gallons of water. In my Scamp it is sitting on top of the wheel well on the starboard side, almost under the sink. This location is good for anything heavy. Too far front or back might have and effect on tongue weight and the towing dynamics.
Boler water setup??? new tank, pump & water heater question Johnny M Plumbing | Systems and Fixtures 7 05-07-2015 12:41 PM
Adding water heater under rear couch seat. dylanear Plumbing | Systems and Fixtures 16 05-28-2012 03:30 PM
Adding water pump Jeff Peterson Plumbing | Systems and Fixtures 7 10-08-2009 07:11 PM
Trouble adding water to a fresh water tank Dan Tracy Problem Solving | Owners Helping Owners 1 05-05-2008 08:11 PM
Hot Water Heater - Rusty Water terryw Problem Solving | Owners Helping Owners 9 07-15-2006 08:33 PM
