Antifreeze in water heater - Page 2 - Fiberglass RV
Old 06-28-2020, 04:29 PM   #21
Escape advises to run the pump ( no water in the fresh tank ) for about 30 seconds to remove any water in it. Done that for 12 years. Still have original pump.
Old 07-01-2020, 11:24 AM   #22
Trailer: Trillium Outback
Saskatchewan
Filling the water heater with RV antifreeze not only takes a lot of the stuff, but RV antifreeze is also hard on the anode rod and will make it erode WAY faster than with just water exposure. I bypass my water heater when winterizing and ensure that the water heater is fully drained before the nights start getting below freezing in the fall.
Machuke is offline   Reply With Quote
Old 07-01-2020, 05:42 PM   #23
Trailer: 1999 Casita Spirit Deluxe
Lawrence
Originally Posted by ZachO View Post
Well in the spirit of continued unsolicited advice, know this: in my experience, camper trailers are constant work. Whether because you screwed up or just because something isn't working right. It's fine, and obviously we all think they're still worth it. Just be prepared.
Great comment. I like learning new systems and taking care of and improving things. With a little luck, my new Casita provide enough fun to justify the learning/work curve.
thunderworks is offline   Reply With Quote
Old 07-05-2020, 07:33 AM   #24
ZachO's Avatar
Trailer: Sasquatch
Montana
It should! With my camper, if it weren't for the constant trouble my fridge gives me, it would be significantly less work. The fridge is 70% of my troubles.
Preserve Antifreeze and use camp ground supplied water? Dsironi Problem Solving | Owners Helping Owners 9 02-12-2014 10:30 AM
Hot Water Tank Smells Like Antifreeze kdhanso Problem Solving | Owners Helping Owners 3 03-24-2012 11:07 AM
RV Antifreeze Legacy Posts Care and Feeding of Molded Fiberglass Trailers 1 10-15-2002 12:04 PM
RV Antifreeze Legacy Posts Care and Feeding of Molded Fiberglass Trailers 9 09-27-2002 11:04 AM
Copyright ©2000 - 2023, vBulletin Solutions Inc.
