My Atwood GC6AA-10E water heater in my 2016
Scamp 13 is giving me problems. This is an electronic spark model that runs off of
propane or 120v. The tank is full of water. When I try to start the water heater on either
propane or electric, I get nothing. For
propane operation, no ignition tries; on electric, I left the switch on for 1 hour; water is cold. I'm getting 12v to the switches, and every other propane appliance works fine. I'm not getting a lock-out
light on the switch panel. The mini-ATO 2-amp fuse on the control board is good (as per a resistance test with a multi-meter).
I THINK it may be the thermal cutoff. Can the thermal cutoff be tested in some way to determine if it's bad? Or, is it safe to bypass the thermal cutoff briefly for testing purposes?
