Bigfoot Propane System - Fiberglass RV
Old 07-15-2023, 11:47 AM   #1
Hi all. So last year I got a 1979 Bigfoot B16. Been slowly using it and going through stuff as time goes on. Anyway I’m now wanting to hook up the propane bottles and test the system for leaks and also all the appliances etc. what’s the best way to do this any advice ?? Also where the bottles mount there’s just a couple hoses is there supposed to be any sort of regulator or adaptor as well ? Any input is appreciated! Thanks in advance. - Willy
WillyBigfoot is offline   Reply With Quote
Old 08-05-2023, 11:03 PM   #2
CharlesinGA's Avatar
With two LP cylinders, you need an auto change over regulator, and pigtails to connect the tanks to the regulator. Out the bottom of the regulator will be 3/8 NPT and a proper gas rated hose going to where ever the hard lines begin.
Marshall Excelsior MEGR-253P-PT15 Standard Regulator and Hose Kit - 15" Pigtail Hoses
You also need a bracket to hang the regulator on the threaded rod that is used for the cylinder hold down.
Marshall Excelsior MEGR-RVB Universal L-Mount Regulator Mounting Bracket
Lastly, you need a vent cover, which is a DOT requirement.
Marshall Excelsior MEGR-862 Regulator Cover 2 Stage for MEGR-291 298 and 253 Series
Here is the Marshall-Excelsior RV and Camping catalog, where on Catalog page 16 (PDF page 18) you will find 3/8 hoses with various ends and in different lengths.
Marshall Excelsior RV and Camping catalog.
Example of one of these hoses, on Amazon.
Marshall Excelsior is all made in the USA and of very good quality, I highly recommend them. DO NOT buy the Flame King regulator and pigtails that will pop up on Amazon, it is junk.
Charles
Charles
'03 Ram 2500 CTD, 5.9HO PacBrake six speed std cab long bed Leer top and 2008 Bigfoot 25B21RB.. Previously, 2008 Thor Freedom Spirit 180, SOLD! 2007 Winnebago View 23H Motorhome, SOLD!
CharlesinGA is offline   Reply With Quote
Old 08-08-2023, 12:36 PM   #3
Ok thanks for the info Charles!
bigfoot, propane
Propane only vs propane/elec water tank heater biker Plumbing | Systems and Fixtures 10 09-24-2021 07:04 AM
Problems with Our Propane System Kevin A Problem Solving | Owners Helping Owners 27 10-26-2020 04:24 AM
Oxygen Propane System Corbett Road Problem Solving | Owners Helping Owners 14 04-22-2019 04:41 PM
Upgrading propane system beardrum Modifications, Alterations and Updates 11 08-06-2013 02:44 PM
75 SurfSide goes for propane system check Scott S. Modifications, Alterations and Updates 5 06-26-2008 07:12 AM
