Black/Grey Water ABS to Fiberglass Connection Question - Fiberglass RV
Old 09-02-2024, 10:55 AM   #1
Just finished our shakedown trip on a new-to-us 2024 13' Standard Scamp (we're the 2nd owners); our visual pre-purchase inspection was fine but it's tough to see every little thing.
Went by the dump station at the end or our trip. Hooked up the hose, noting that the bayonet hose port faced to the rear of the trailer, as opposed to side of the Scamp like the grey tank port does. When I opened the black water valve, the entire ABS elbow, slide valve, bayonet fitting and slinky hose fell off the trailer, and thus baptised my arms in black water. Joy!
It looked as if the elbow had never been securely attached to the fiberglass stub end that terminates just flush with the bottom of the trailer subfloor. It's not clear to me whether this was to have been a glued connection.
Upon closer inspection at home, it seems the elbow itself was a repair job due to a crack, possibly from some impact. It seemed to be a pretty solid repair though. Nothing that would have caused the joint to fail. As far as I can tell some wax from the toilet ring was used to coat the inside of the hub connection on the elbow before pressing it up onto the fiberglass stub, but no other adhesive or sealant appears to have been used. As opposed to the grey tank piping, the black piping was not supported with any pipe hangar strap.
Some questions:
- is the ABS piping intended to be glued to the fiberglass? I can see why it would be preferred *not* to glue this joint, so as to allow removal of the assembly for future repairs
- if glued what adhesive to use?
- if no what is normally used to support the ABS pipe assembly (vertical elbow, slide valve, horizontal elbow, + bayonet fitting)?
If nothing else, I propose to re-apply some wax to the upper elbow, firmlyu slide it back into place, and install some hangar strapping to carry the weight of the assembly. Does that sound right?
Achilles is offline   Reply With Quote
fiberglass
Bigfoot grey water pipe leak at grey tank pianopc Plumbing | Systems and Fixtures 1 08-13-2021 06:33 AM
Fresh water tank: ABS or Polyethylene? Dail Plumbing | Systems and Fixtures 7 05-23-2021 09:47 PM
How do I get my grey water into my new grey water tank? Bryan L. Problem Solving | Owners Helping Owners 5 10-16-2020 05:16 PM
Grey or Black Water Tank on 13' Trailer? sj2moncton Plumbing | Systems and Fixtures 4 09-14-2010 05:14 AM
Black water-Grey Water ROIDON L Plumbing | Systems and Fixtures 3 07-23-2009 06:09 PM
