Casita sink faucets only dribble water.
My water system was full of ant-freeze, and I have been blowing out pink water and foam using the city water and freshwater tank. The sink faucets *were* working fine, water was jetting out of them. Now, water is only dribbling out.
The bathroom faucets and toilet still work fine. Water jets out of them.. What could cause the Hot and Cold faucets to stop working? I assume they are clogged with something. I think the bathroom faucets are the farthest down the water line, so it is weird the sink had no water pressure. I am guessing the hot and cold line between go up to the actual faucets are where the problem is. Right after the pex lines split off from the main water line to go up to the sink faucets, wherever that happens.
I might try to blow the lines out with air, maybe air can clean clogged lines better than water.
Any suggestions?
