Casita water tank change out? - Fiberglass RV
Old 09-08-2022, 10:15 PM   #1
Trailer: 2018 Casita 17' Spirit Deluxe
Has anyone changed out the 16 gallon fresh water tank to the 23 gallon tank and if so, how hard was it to do.
Thanks,
Dave
slonecker is offline   Reply With Quote
Old 09-09-2022, 04:11 AM   #2
Trailer: Boler 13 ft
The fresh water tanks were already taken out of my Casita when I got it and I liked having the space for storage, so I hung an 21 gal. tank under the floor in rear between frame using "C" clamps. 3/8 threaded rod and 1-1/2 angle stock. It doesn't hang any lower then the Gray tank and was easy to do.
Old 09-09-2022, 05:28 PM   #3
Trailer: Casita SD
I would guess that changing out the existing tank would involve temporarily removing the fiberglass shell under the bench seat cushions.
JoelInTexas is offline   Reply With Quote
Old 09-14-2022, 09:44 AM   #4
Trailer: Currently Shopping - Past owner of 2004 DSDP.
FL
You need to remove the rear fiberglass (door side) seat, it has screws along the back side, two coming in under the sink area and a few along the floor. If you purchase the tank from Casita or Little house customs it should be as simple as removing the old tank, moving the two floor supports / anchors, getting a larger metal clamp and placing it back in place. Fairly easy job. The fill and connections should all line up.
jason laughren is offline   Reply With Quote
Old 09-14-2022, 10:59 AM   #5
Trailer: 1994 Casita 16 Liberty
water tank
My 1994 Casita had a 10 gallon fresh water tank. Replaced with a 25 gallon fresh water tank. Very easy as I lifted out the fiberglass bench and found lots of room for the 25 gallon fresh water tank. Sure do enjoy the extra water,
DanielAG is offline   Reply With Quote
Old 03-26-2024, 04:10 PM   #6
Name: Laura and Rob
Trailer: Casita Liberty 2018
Unhappy Broken shower drain line on my 2018 Casita
It appears that the shower drain line under my casita...which has a screw in-line filter...loosened from one side and broke the black connecter ring (right side). The side that broke is glued in place so I can't just unscrew and remove it to put a new one on. I am told by Casita service that I will have to cut the
1 1/2 PVC and then glue the new connector on. Problem is there is and elbow about a couple of inches from where the line needs to be cut. I have ordered a new filter and connector.. Has anyone else run into this problem?
LauranRob is offline   Reply With Quote
Old 04-03-2024, 11:33 AM   #7
Trailer: Currently shopping
Moraga
Water tank change.
The hardest part of the change is where you’ll put the mattress and table top.
There is not much room in the Cacita.
You will need a roll of teflon tape and what I call plumbers tape.
Plumbers tape is metal with holes along its whole length.
I paid about 3 dollars for 23 feet , it’s not expensive.
The change shouldn’t take more than 2 or 3 hours.
BradleyCrandall is offline   Reply With Quote
Old 04-04-2024, 06:56 AM   #8
Not an easy fix in my opinion. Too many connections, too close together. The vent pipe makes it hard to just cut it all out and start over. It might be time to experiment with some rubber radiator hose and a couple of stainless hose clamps.
Jimmy J is offline   Reply With Quote
Old 04-07-2024, 10:41 AM   #9
Name: Laura and Rob
Smile Shower Drain Replacement Kit
Thank you for responding! We purchased a shower drain replacement kit from Little House of Customs in Texas. Received it via USPS this week. Doing the work this weekend! Thanks again!
Old 04-07-2024, 11:23 AM   #10
Please post results when you're done. Had similar issue with 2002 model and would like to see you how you did it.
Thanks.
Old 05-02-2024, 06:08 AM   #11
Trailer: 2018 Casita LD
Thanks,
Dave
Good timing. I'm about to start something similar. I already have a 25-gallon tank but for the sake of balance and storage I'll be relocating it to the center of the Casita, under the bed. As part of this I'll be moving the pump and adding a proper filter. I've planned it out and nothing looks too complicated except I don't know what the inlet tube/hose is made out of and I'll have to extend that. Anyone have any idea what it's called?
SnowballCasita is offline   Reply With Quote
casita
How to use all water in hot water tank and cold water tank? (Scamp) Scamperino Plumbing | Systems and Fixtures 25 06-03-2022 06:18 AM
Casita - water from fresh water tank charleserwin Problem Solving | Owners Helping Owners 20 12-30-2016 04:43 PM
Change this change that jgraps1958 Modifications, Alterations and Updates 17 10-09-2014 08:23 AM
Gray water w/out tank Janine Problem Solving | Owners Helping Owners 10 08-29-2007 03:06 PM
