12-23-2019, 10:48 AM
Trailer: CASITA
Extra propane tank for Grill 5# vs 11#
I thinking of getting a extra propane tank to carry for my grill and stove. I have the napoleon 285 grill and the camp chef Everest stove. These are both high pressure systems so Rather than convert to use on my rv system. I am thinking of carry a smaller tank. You can buy a 5 lb or 11 lb for about the same price. Witch would be the better one to chose? Anyone have any experience with either system ?
12-23-2019, 10:54 AM
I have a 10 lb. and before that a 5 lb.
The 10 lb. doesn't need to be filled as often, which is a good thing, because you are likely to run into inadequately trained staff at filling stations who don't know how to fill anything other than a 20 lb. cylinder.
I start my trip with a full tank, which doesn't require filling until I'm home again ( I don't have a propane fire in a can ).
12-23-2019, 11:29 AM
Trailer: Escape 17 ft Plan B
I use a 5 pound tank. The only problem I have is feeling a bit guilty asking to have it filled since they do the same amount of work filling it as with a 20 pounder, and only put in a gallon of propane.
You will also run into places where they price by the tank rather than read the meter, and have no idea what to charge for a small tank (or will try to charge the same as they do for a 20 pound tank).
12-23-2019, 02:58 PM
Trailer: 2013Escape 21
Iowa
11 lb tank
We have the 11 lb tank. I use it for our WeberQ, Everest and Campfire in a can. I only have it filled at my local hardware store and they don’t mind the small tank. I usually take a 20 pounder in at the same time. I start the season with it full and then usually fill it once or twice the rest of the season. I use it on the campfire a few times a season. It will run 2-3 hours the way I run it on about 1/4 a tank. It fits nicely in the front box on our 21. I like the bigger tank. YMMV.
Iowa Dave
12-23-2019, 06:56 PM
Trailer: Boler 13 ft
I use to carry an extra 20 pound tank with me but this summer on our cross country trip I bought an adapter that goes onto the 20 pounder and refills the green 1 pound tanks.
I carried 4 - 1 pounders in a tray I built and only used them when ever I grilled or wanted to use the lantern.
One, 1 ponder could be used to cook about 5 suppers and 5 breakfasts before needing to be refilled.
12-23-2019, 07:08 PM
We carry an 11 lb tank for grilling. Got tired of the little green tanks always running dry right in the middle of grilling a steak or a rack of ribs
Fill the 11 lb tank in the Spring and again in the middle of summer — Easier / Cheaper!!
12-23-2019, 07:37 PM
Trailer: CASITA
I was also looking at the refillable bottles, what i like about these as they don't have to be empty to refill and i think much safer than refilling the throw aways.
https://www.amazon.com/gp/product/B0...0?ie=UTF8&th=1
12-24-2019, 05:38 AM
True but to avoid this, I would always put a newly refilled tank on if I knew I was going to cook something that was going to take awhile. This is why I had 4 tanks.
When I used up 2...I would refill them and put them in the back of the rack.
I really should look into the refillable tanks and not just the throw/away ones for safety reason because on the trip I did have one tank that did leak through the valve.
But on the same hand, I've had new tanks that were never refilled, that leaked when they got low on pressure.
12-24-2019, 09:44 AM
Trailer: Hymer
I got a splitter and an extension hose from Amazon and just run my Weber grill off one of the 20 pounders on my trailer. Works great and cost about $20 IIRC.
12-24-2019, 10:38 AM
I use two 20 lb tanks held in the propane storage area of my trailer. Never run out of both tanks, and always have good propane from my low pressure quick connection. No more of those environmentally and sustainability poor 1 lb tanks, and no having to pack along another tank either 5-10-20 lbs as I have enough other stuff as it is with me as it is.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
12-24-2019, 11:19 AM
Trailer: Cadet
I replaced our 20 lb. tank with one 5 lb. tank to reduce the weight and to provide a bit more space on the tongue. We use it for a Coleman stove and the furnace. After 21 nights it was about 1/3 full. Where I get my refills they charge for a complete refill regardless of what you need. At $7 to $8 I'm fine with that.
I'm about to ad a second 5 lb. tank for an on demand hot water heater I'm adding to the trailer. If I deplete one tank the second will serve as a back up. I will then get full value when I get refills!
New 5 lb. tanks around here cost about the same as a 20 lb. tank. It seems crazy but I guess it's a matter of supply and demand. I'm sure they're available but I haven't seen 11 lb. tanks for quite a wile.
12-24-2019, 01:02 PM
Massachusetts
For what it's worth.
I have found that Tractor Supply charges only for the amount of propane they actually put into your tank. And they seem to be located just about everywhere.
12-24-2019, 03:02 PM
Trailer: BigFoot 25B25RT
Massachusetts
Oh good tip I will have to check into that,,,thanks
12-24-2019, 03:37 PM
Puget Sound, WA
The 11-lb cylinders come in two different configurations. We have the short ones,
The short ones basically fit on the trailer’s A-frame in place of the usual 20-lb cylinders. They are also quite stable when placed on the ground. One fits tightly in a plastic milk crate.
The taller ones look like they would be less stable on the ground, but I believe you can get a detachable foot or legs which will make them more stable.
12-25-2019, 06:41 AM
Trailer: 2017 Escape 5.0 TA
Connecticut
Yeah, what you said👍
12-25-2019, 01:56 PM
Many Uhaul locations also have propane and refill any size tank. They only charge what they put in the tank. I have an 11 (or actual 10) lb tank that I use for my propane burner for my coffee roaster. No way am I paying for 5 gallons when I only need 1 or 2.
Can't stand those gas stations that will fill but require a minimum of 5 gallons. A few years ago I once brought in two 20lb tanks. Each was about 3/4 empty. I confirmed first that the minimum was 5 gallons. Between the two tanks it came to abut 7 gallons. When the guy rang me up he wanted me to pay for 10 gallons. Me: "no, you said a minimum of 5." Him: "5 per tank." Me: "nope, that wasn't the agreement." Him: "I'm going to call the police if you don't pay for 10 gallons." Me: "call them. I haven't done anything wrong. I'll pay you what we agreed on, or you can take your propane back and I'll take my tanks home." He agreed to 7 gallons and I went home.
12-26-2019, 07:42 AM
Trailer: Escape 2019 21. Tow Vehicle 2019 4Runner
Jim I have pondered about doing things your way. I have the same storage box on the outside of my E-21. Then there are the logistical issues to consider which has held me off. Do you physically remove the 20# tank and bring it to the cook stove?
12-26-2019, 07:46 AM
Mike is this Manchester Cylinder similar to what you are using?
12-26-2019, 08:09 AM
Trailer: CASITA
Lots of good info here. I starting to think the little one pound tanks or hooking into rv system would be the best way for me to go. These two seem to have the weight savings. I already have a heavy grill as picked the Napoleon 285 grill and camp chef Everest. Both are not the lighted choices but i feel the guilty is worth the extra weight. maybe even a combo of both grill hooked to rv and stove on the one pound cans.
12-26-2019, 08:07 PM
Puget Sound, WA
Originally Posted by Telescopist
Yes, that's the one, model 10393.1. They have the same 12.2-inch diameter as the standard 20-lb (and 30 and 40-lb).
https://www.mantank.com/products/dot...e-cylinders-2/
