Faucet fittings - Fiberglass RV
Old 11-11-2020, 09:41 AM   #1
Trailer: 2004 Bigfoot 25 ft (25B25RQ)
Faucet fittings
I'm not a plumber, but I do some repairs around the house. I bought a replacement kitchen faucet for my 2008 Bigfoot, but of course the fittings don't match.
I'd appreciate any information that can help me order what I need online. My family and I are staying very secluded and don't risk going into stores.
Thanks!
Phil Ruffin is offline   Reply With Quote
Old 11-13-2020, 11:36 AM   #2
Joe MacDonald's Avatar
Trailer: 1981 Trillium 5500
with what I see in your hand, it looks like standard house tap feeds, do you know if they are for 1/2 inch pipe? Picture of your new taps and both ends of the hoses would be helpful
if so, the plastic pipe you have as plumbing feeding the sink appears to be 1/2 inch PEX, you can get replacement fittings from WATTS, in plastic that convert from pex to 1/2 inch pipe thread, those would hook up to the hoses in your hand. just cut the old fittings off, make your cut clean and square, then put on the new fittings
Old 11-13-2020, 12:37 PM   #3
Thanks
Thank you, Joe.
Yes, it's a standard fitting for home installation and the other end is inside the faucet.
But I have to return it. The faucet is a tall, one-hole unit that will get in the way of opening the cabinet doors above/behind it.
I'm hoping to find another one like it, but shorter. This one has touch-on, touch-off capability, so I'm thinking it will make it easier to conserve water.
Plumbing fittings? Jake Jacobson Plumbing | Systems and Fixtures 13 10-26-2008 04:13 PM
Where to Buy? New propane lines, fittings, etc? Kurt in BC Problem Solving | Owners Helping Owners 9 06-12-2008 05:27 PM
Gray water fittings and connections? Roy in TO Plumbing | Systems and Fixtures 4 06-02-2008 11:52 PM
Exterior Fittings DanPatWork Problem Solving | Owners Helping Owners 2 01-09-2008 08:49 AM
Qest Replacement Fittings Victor Benz Problem Solving | Owners Helping Owners 0 07-28-2006 12:37 PM
