fresh water tank leak - Fiberglass RV
Old 11-18-2020, 11:21 AM   #1
Trailer: 2004 Scamp 16 ft.
Whats the fix for aleaking fresh water tank on a 2004 Scamp 16. Do you have to remove entire inside back of camper ?
Brownhaven is offline   Reply With Quote
Old 11-19-2020, 10:46 AM   #2
you have to unscrew the bench on a 13 footer and cut the closet sealed silicone. you need a long square driver bit on the 13 since you cant get between the tank and the cabinet side. at least this was the case when I replaced the hoses on my 1986 Scamp 13. there are screws in the bench into the back wall too. Get a light in there and wear a head lamp too. hope your 16 has more room in there than my 13 did.
Old 11-19-2020, 03:27 PM   #3
leaking fresh water tank 2004 scamp 16
Thanks Steve sounds like more of a job than I want to tackle
Old 11-19-2020, 06:37 PM   #4
sokhapkin's Avatar
SW Florida
Actually this is a pretty simple job. I had to repair leaking drain valve connection on my 2014 Scamp 16. Remove the dinette table and the passenger side bench.
Sergey
city water fills fresh water tank drmarylynn Plumbing | Systems and Fixtures 10 05-23-2017 08:35 AM
Casita - water from fresh water tank charleserwin Problem Solving | Owners Helping Owners 20 12-30-2016 04:43 PM
Auxiliary Fresh Water Tank, Transferring Water Adrian W General Chat 0 09-05-2010 02:36 PM
Trouble adding water to a fresh water tank Dan Tracy Problem Solving | Owners Helping Owners 1 05-05-2008 08:11 PM
