Graywater fitting broken - Fiberglass RV
Old 11-27-2020, 01:56 PM   #1
WI
Hi all,
I was trying to replace the sink drain setup in my new-to-me 2001 Scamp. In the process I cracked the gray water fitting and need to replace.
Two questions
1. How do remove the screws(?) That are holding the connector in place? They have a hole thru the center and nothing to latch onto.
2. Anyone know where I can order a replacement part? I didn't see any on the scamp website.
Thanks, Caitlin
Ps- I'm new to Scamps/RVing in general so I apologize in advance if I ask any dumb questions/use the wrong terms
Drawkcab is offline   Reply With Quote
Old 11-28-2020, 08:43 AM   #2
Trailer: 13 ft Scamp
Originally Posted by Drawkcab View Post
Hi all,
Two questions
Thanks, Caitlin
They look like rivets so you would have to drill them out
Old 11-28-2020, 10:57 AM   #3
AC0GV's Avatar
Wisconsin
Not a screw
Hi all,1. How do remove the screws(?) That are holding the connector in place? They have a hole thru the center and nothing to latch onto.
That is a pop rivet and needs to be drilled out. Use a slightly larger bit and just drill off the head.
Is it this one?
https://www.amazon.com/Camco-37271-E.../dp/B003VATEFS
Old 11-28-2020, 12:13 PM   #4
Depending on how bad the crack is, You may be able to repair it.
Plumbers Goop and other plastic glues.
Can you take a picture of the crack?
Trillium 1300 Axle Check, Fitting Electric Brakes Richard Hayes General Chat 2 08-23-2009 10:54 PM
custom fitting a memory foam mattress Phillip Modifications, Alterations and Updates 12 06-02-2009 05:00 AM
thoughtful engineering and fitting-out? Richard Davis Care and Feeding of Molded Fiberglass Trailers 13 08-08-2008 07:37 PM
Really crummy Scamp shower fitting Steven Tonnesen General Chat 15 02-13-2006 11:39 PM
Graywater tanks. Legacy Posts Care and Feeding of Molded Fiberglass Trailers 3 10-02-2002 12:06 PM
Copyright ©2000 - 2023, vBulletin Solutions Inc.
