Greywater plumbing to tank on Burro - Fiberglass RV
Old 06-07-2022, 10:03 AM   #1
Trailer: Currently Shopping
Does this plumbing to my greywater tank on my 1990 Burro make sense to anyone? Both the water entering from the shower and sink, and the water exiting to the the greywater drain valve, are connected to the single fitting at the very bottom of the tank. The tee in the front of the picture is picking up the shower and sink lines. The water exits to the right to the valve that is out of sight. I am considering adding a fitting as close as possible to the top of the tank for an inlet?
frthompson is offline   Reply With Quote
Old 06-07-2022, 07:51 PM   #2
Paul O.'s Avatar
It does not matter if the tank is a "flow through", or a "dead end", which this picture seems to show. It is a simple buffer for the grey water. Water will still flow into it, in one direction and out of it in the opposite direction, when the drain valve is open. Of course, the tank needs to have a vent or overflow somewhere at the top of it. You can find it if you simply overfill it and look for the extra water outflow, or just keep looking for it, it should be there. I would leave it alone.
Old 06-07-2022, 08:40 PM   #3
OK, I see your point, the water will seek the same level in the tank and in the pipe, thanks-- Frank
burro
Greywater Tank in 1976 Trillium 1300 MOandJeanette Modifications, Alterations and Updates 13 09-30-2015 04:52 PM
Scamp Greywater Tank Mounting Peter L Plumbing | Systems and Fixtures 4 12-17-2013 06:38 AM
Scamp 16 Greywater Project Chris Krumm Problem Solving | Owners Helping Owners 5 06-25-2008 06:30 PM
New greywater tank delivery! Christine V General Chat 0 08-28-2007 08:32 AM
plumbing plumbing plumbing..... Herb P Plumbing | Systems and Fixtures 6 06-17-2007 06:01 PM
