Hand rocker pump - Fiberglass RV
Old 05-03-2020, 10:12 AM   #1
Rarebird's Avatar
Trailer: Trillium 4500
Hand rocker pump
Hi, all campgrounds are closed so I may as well work on the trailer. I need to replace this, it is old, from a 1978 Trillium 4500. I have seen a couple online, with wildly varying reviews. Any suggestions? Stay well.Click image for larger version
ID:	134360Click image for larger version
Rarebird is offline   Reply With Quote
Old 05-03-2020, 01:46 PM   #2
Raz
Raz's Avatar
In general marine equipment tends to be better quality (and pricier ) than RV stuff. You might try a marine outlet. West Marine and Defender are two that come to mind.
Old 05-03-2020, 04:49 PM   #3
Trailer: Trails West
if it was mine to work on the first thing I would do is take it apart and see if replacing Orings or washers and perhaps a spring could restore it to functioning condition. It is rather fun to tear such things apart just to see how they work even if they can't be restored.
Old 05-03-2020, 05:22 PM   #4
I'm looking to replace mine on the Czmpster too. The handle just flops. It used to work. I guess no harm done it taking it apart. Worst case is having to replace it (or patch a hole).
Dave Fish is offline   Reply With Quote
Old 05-04-2020, 10:27 AM   #5
Trailer: 13 ft Ventura
I found that rebuild kits are usually on the shelf at RV parts stores.
I went through a couple until I found a nickel-plated brass rocker pump out of an old fish boat. This one's built so well I can leave it in my will
Darrell O is offline   Reply With Quote
Old 05-05-2020, 01:05 AM   #6
https://www.amazon.com/TMC-Stainless.../dp/B06XDP33MT
That link shows a hand pump that looks to possibly be an exact size replacement. The Amazon listing does state the dimensions of the cutout hole so that would be a good thing to check before you order it.
Just as a general information note to help find replacement parts such as this. Use keywords and then select for an image search. Images are a great way to turn up items that look to be exact fit replacements. The keywords I used were
"RV sink hand pump"
Old 05-05-2020, 03:57 AM   #7
Brian G.'s Avatar
Trailer: '73 & '74 Hunter
Hi Marjie,
When I removed my old hand pump and examined the internals I found them disintegrated and I judged it a total loss. I purchased a handpump from Vintage Trailer Supply, product number VTS-699, for $34. The new pump is functional and I like it. But it doesn't feel as solid as the original (1973). When I pump it, I feel the need to grasp the base with my other hand. The instability might not be workmanship of the new pump - I don't know for sure - it could be that I had to modify my countertop to accommodate the different sized base of this replacement pump.
Brian
Brian G. is offline   Reply With Quote
Old 05-05-2020, 04:09 AM   #8
Brian G.'s Avatar
Here is the new handpump installed.
Old 05-05-2020, 08:19 PM   #9
Rarebird's Avatar
Yes, I am familiar with West Marine. The part was a bit too expensive, but probably better than the replacements I found. Thanks for the suggestion though.
Old 05-05-2020, 08:20 PM   #10
Rarebird's Avatar
I love taking things apart! Just may do that!
Old 05-05-2020, 08:21 PM   #11
Rarebird's Avatar
"RV sink hand pump"
Thanks, I did see this. The reviews are not so good, for this and another similar one. May have to go for it though.
Old 05-05-2020, 08:22 PM   #12
Rarebird's Avatar
Originally Posted by Brian G. View Post
Hi Marjie,
Brian
Yes, this is one I was considering. Mediocre reviews, but not much choice out there. Thanks.
Old 05-05-2020, 08:24 PM   #13
Of course the reviews for the original might have said the very same thing about the pump if back then they had those internet reviews around.s
Old 05-05-2020, 08:54 PM   #14
Civilguy's Avatar
Puget Sound, WA
Yes!!!
Old 05-09-2020, 10:40 AM   #15
Here are some options
https://www.google.com/search?q=mari...zepuW411unXUM:
Jon31433 is offline   Reply With Quote
Old 05-09-2020, 10:56 AM   #16
Steve Hilby's Avatar
Trailer: Compact Jr
The Valterra pumps are rubbish. The body (housing) is plated plastic, and the bosses where the handle and spout are attached are nowhere near strong enough; if you tighten the gland nut, trying to get it to stop leaking, the boss cracks and the whole thing is ruined.
What I suspect happened is that when Valterra went to a plastic housing, they simply copied the metal housing directly, with no thought for the differing material strengths of metal and plastic.
Steve Hilby is offline   Reply With Quote
Old 05-09-2020, 12:23 PM   #17
Trailer: U-Haul 13 ft ('Lil Eggo')
I was actually able to obtain the washers and rings at my local Ace hardware - takes a little time to get the correct ones but if you take your old ones in to size correctly they have TONS of different washers and o rings to choose from and ended up being much cheaper than buying the refurb kit from Camping World. Mine looks slightly different from yours but probably similar guts. I even had a miniature sewing machine from the 50’s that used a 2” rubber wheel - found an o ring there that worked perfectly - and was like $ 1.29.
I also ended up getting a small pump and single filter faucet to use with my battery. Like it MUCH better so don’t really use my pump much now - but kept it installed anyway...
Sharon W is offline   Reply With Quote
Old 05-09-2020, 05:42 PM   #18
Doc.Kev's Avatar
I just replaced mine this week. The old one cracked when a freeze hit and I hadn’t winterized. I got a Valterra RP800 on eBay for $30, free shipping.
Doc.Kev is offline   Reply With Quote
Old 05-09-2020, 06:14 PM   #19
RLP
Trailer: 72 Boler
When I acquired my 13 foot Boler. the hand pump would not pump water. I took it apart and noticed the leather seal was very dry and cracked. Could not find a replacement. Then in Princess Auto I found a package of assorted replacement seals for hydraulic cylinders. One of the rubber ones looked like it might work for me. Long story short, it's still pumping water. Pump on!!
RLP is offline   Reply With Quote
Old 05-11-2020, 04:41 PM   #20
Trailer: Lil Bigfoot 1988 B13.5
I added a small 12 volt pump to mine and hooked it up inline. I can now use a tap instead of pumping. I still have my hand pump just in case but it rarely gets used now. Flip the switch, get water, shut it off. I have a thread on here that shows what I did. Great upgrade I think.
Drtriumph is offline   Reply With Quote
old Coleman Hand Rocker Pump Peggy Problem Solving | Owners Helping Owners 1 08-28-2009 09:05 PM
No more hand rocker pump.... kentj Modifications, Alterations and Updates 7 07-18-2008 01:15 AM
1976 Trillium Rocker Water Pump Bill C Problem Solving | Owners Helping Owners 12 04-25-2008 06:48 PM
hand pump faucet lost it's prime, What's easy way to prime it? Curtis F. Problem Solving | Owners Helping Owners 16 04-10-2007 05:00 PM
» Trailer Showcase
we-2
lloyd
THE boler
Luis
