Originally Posted by Jann Todd
Bottled water comes from a faucet. Bottled spring water comes from springs. Read this in a health magazine.
That depends on the brand. But yeah virtually none of it is as fancy as they want you to believe. But most of it is better than the left would want to you believe.
Yes most of it originates from municipal water plants. Now pop is pretty much bottled water just like your home tap. The same thing with the water in the fountains at food places. If just has carbonation and flavor added. Interestingly McDonald fountain drinks actually do have better water. It goes through a filtration system first. but that is pop.
People complain about the cost of bottled water as compared to pop and a lot of the reason for this is transportation Pop is bottled (and canned) in more places so bottled water has to be transported farther.
Some bottled water does come from independent sources. You will note that the left says it all comes municipal plants. But then they complain about the plants that use their own sources for "stealing water that should be free." Kind of tells you how much they care. But here is the general truth. But realize that there is no standard other than the one that is for municipal water which the bottled water places have to follow. And their marketing really has not meaning so they can do what they want.
Most of the bottled water comes through a similar process. Most of it starts with municipal water. But municipal water travels through municipal water distribution pipes, and a lot of those are not very good and lower the quality. For pop as long as the water is still EPA level safe that is all they worry about. But they do pay more attention to bottled water. Now some places just do bottle it in the same plant and machines as the pop, just without carbonation and flavor. But most of their own plants. These plants are located closer to the water plant. Then they make sure the pipes feeding them the water are modern and cool quality. Not just average or less.
Then the plant will have some level of filtration. Much more than the water from city system. Then they will use higher quality plumbing to feed the water into bottling.
So bottled water and tap water are not quite the same.
