kitchen sink faucet broke on Casita SD17 - Page 2 - Fiberglass RV
Old 01-20-2021, 07:50 AM   #21
Joe MacDonald's Avatar
Trailer: 1981 Trillium 5500
if there is enough play in your line, i would trim the pex, make sure your cut is square, and install a new connection piece, I have had good success with Watts plastic push on fittings, none have failed so far- 5+ years, they make a female thread to pex adapter, in 1/2 inch
Joe
Old 01-20-2021, 08:10 AM   #22
Treat yourself to a nice faucet and forget the cheap RV faucets.
Life tis too short to have to deal with crap every day. I installed a nice one that pulls out and has a sprayer.
Old 01-20-2021, 09:46 AM   #23
Trailer: 2018, 21ft escapeó 2019 Ram 1500 Laramie
Be aware that many of the faucets sold at big box retailers whether metal or plastic are junk . Finding a quality brass faucet with good chrome plating for $29.99 is a pipe dream IMHO
Try finding replacement parts for a 10 year old HD faucet
Old 01-20-2021, 10:08 AM   #24
Awfully wide brush
I bought my faucet at a big box store and it was not cheap and has held up well.
Of course my setup is only 5 years old and has been from coast to coast and Canada to the border and Key West and points between.
Almost any faucet will beat an RV faucet.
I would not put up with any leak in the water system.
Old 01-20-2021, 10:29 AM   #25
Trailer: C
Iowa
I have some plumber's tape I used on the Anode, I will try and put some inside the pex fitting and see if it stops leaking.
whoot is offline   Reply With Quote
Old 01-20-2021, 10:33 AM   #26
Originally Posted by redbarron55 View Post
Awfully wide brush
My point was whether you buy a $5 RV faucet or a $5 faucet at a big box retailer itís still a $5 faucet . Well machined quality brass and heavy chrome plating are not cheap . Replacing a low quality RV faucet with a low quality big box faucet does nothing except kick the problem a short distance down the road.
Evidently my point wasnít clear or my brush was too wide , so be it .
Old 01-20-2021, 11:07 AM   #27
Trailer: 2008 Casita 17' SD
A few words of caution. You should never use Teflon Tape, (aka Plumber's Tape,) on any threaded PEX fittings! If you already put some in there, I'd recommend digging it all out. PEX fittings will not seal well, (if at all,) if you wrap the threads with Teflon Tape. Just my suggestion.
Old 01-20-2021, 11:19 AM   #28
Trailer: Trail Cruiser
Only one more part to go and then no more leaks. Good luck and happy camping.
Old 01-20-2021, 11:35 AM   #29
Trailer: C
Iowa
Should I use something else to seal the fitting? Like "thread sealant" or "pipe dope"?
Old 01-20-2021, 12:51 PM   #30
Nope. PEX threaded fittings are designed to be used as they come. No pipe dope, thread sealant, etc. They work by creating a compression seal. In fact, you can ruin or crack a PEX threaded fitting my using anything on the threads.
Old 01-20-2021, 01:04 PM   #31
Trailer: C
Iowa
Yikes, ok, I will just blast it with compressed air or something. Maybe there is debris in it.
Old 01-23-2021, 12:18 PM   #32
Trailer: C
Iowa
I may have fixed the leaking faucet. I depressurized the water system, and hand-tightened the hot-water connection as much as I could. It seems to have stopped leaking. I think tightening it when it was pressurized, was not going to stop it from leaking. I will keep a bucket under the connection until I am sure, but it looks good for now.
Old 02-15-2021, 09:21 AM   #33
LarryB.'s Avatar
Trailer: Casita17'Spirit Deluxe (aka: Tweaker's Casita)
Southwest Ohio
I had a similar issue with my Casita's kitchen faucet leaking at the base of the spout. I found that by loosening the compression fitting at the base of the spout, the spout can be removed and the problem might be the rubber grommet at the base of the spout.
However, the root cause in my case was excessive water pressure and over-tightening of the plastic compression fitting caused it to crack. After replacing the faucet with a similar high rise faucet, I eliminated the issue by using a pressure reducer when connecting to "city water". You can get one at Amazon and they are also available at Home Depot, Walmart and other retailers.
LarryB. is offline   Reply With Quote
Old 05-07-2021, 08:04 AM   #34
Trailer: 2014 Casita Spirit Deluxe
I love this upgrade you did on the sink and stove.
Did you have to do any modifications to the fiberglass to get the new stove or sink installed?
Any issues with the gas line or water connections?
thank you!
amytutoki is offline   Reply With Quote
Old 05-07-2021, 09:29 AM   #35
Amy,
I sent you a reply to your message.
Greg
Old 07-09-2023, 04:31 PM   #36
Canada
Love It!
Or you can go totally overboard like I did and replace the whole useless "birdbath" they call a sink with a new larger and deeper sink that comes with a chromed brass gooseneck faucet (yes real chromed brass, not chromed plastic,) with one of these:
Krowne Model 1419 (And it comes with the faucet in the picture, as well as a stainless steel drain fitting included.)
https://www.katom.com/381-HS1419.html
Oh, and my new two burner galley stove to replace that miserable Suburban POS too!
https://pantherrvproducts.com/dometi...st-iron-grate/
So Awesome Greg! I'd love to do exactly the same thing. Any tips for install or ordering?
thanx,
Clay D
Clax is offline   Reply With Quote
Old 07-13-2023, 06:07 PM   #37
Trailer: currently shopping
Wow this is beautiful!
highcotton2186 is offline   Reply With Quote
Old 07-14-2023, 07:10 AM   #38
thanx,
Clay D
I'd start with the sink, and make the "enlargement" for the new sink as close as you can to the bulkhead where the microwave/fridge is. From there, as to the stove, I went with as little as I could get away with for the fiberglass strip between the stove and the sink. It really doesn't matter as to the strength of that fiberglass strip between the two since both are, in and of themselves, rimmed with a stainless steel lip for strength. Your sink and stove, when assembled should be just about touching in between. This will allow the gas line for the stove to fit up without any extra effort. I did have to replace the 3/8" straight gas fitting that came with the stove with same fitting with a 90 degree bend, so that I could hook the existing gas line up from below easily. There won't be any room for bending pipes to fit to a straight gas fitting on the stove. Not a big problem, but just something to change out so the stove will fit in the cabinet.
casita
Anyone know what model faucet is used on Escape 19 kitchen sink? BatDude General Chat 2 10-07-2018 02:32 PM
2000 Casita SD Kitchen Faucet - Need Replacement RobertaF Problem Solving | Owners Helping Owners 3 12-03-2012 03:38 PM
When i say i'm broke ... I'm broke! ScottG Jokes, Stories & Tall Tales 3 06-23-2011 12:38 PM
Single Handle kitchen bar faucet Sheryl M Problem Solving | Owners Helping Owners 4 05-11-2008 08:56 PM
Kitchen Faucet and Pump for U-Haul CT Jeanne and Steve Problem Solving | Owners Helping Owners 7 06-17-2007 09:25 PM
