LP Connections for Custom Stove Setup - Fiberglass RV
Old 07-31-2020, 03:06 PM   #1
Trailer: Trail Mite
I pulled the 2 burner stove out of my ‘72 Trail Mite because I prefer to cook outside and would like to free up the counter space.
I’d like to add a quick connect to the line from the stove, so I can quickly attach the 12’ hose with pressure regulator I have, and set it up so it can be used with both my onboard 20lb LP tank and a 1lb green tank (for when I want to travel light and leave the trailer at home).
Searched online for the right fittings without much success, not even sure what I’m looking for. Any ideas?
I’m new to this, but it looks like it’s a standard 3/8 flared attachment from the stove.
31679C46-4467-44FA-985A-2FBB75869EBB.jpeg   C691DFBF-1244-45CB-9AF3-6D2D97C3D556.jpeg
Miles 0 is offline   Reply With Quote
Old 07-31-2020, 03:24 PM   #2
If you want to use the existing copper stove gas line to extend out for your outdoor stove, the piping needs to be removed from the inside of the trailer and any pipe connections need to be made outside, (underneath.) The RV and Gas Codes do not allow for branch lines or connectors inside the trailer unless it is the sole connection to the appliance itself. No "piggy backing, splitting, wye connections," or any interior couplings are permitted. It might be to your advantage to just remove that section of gas pipe and choose a spot under the trailer next to the frame where you want to have your hook-up for your outdoor stove, then reroute your gas line along the frame to where you want to install your plug-in.
Old 07-31-2020, 03:29 PM   #3
Trailer: Trail Mite
Thanks Greg! Yes I removed the flexible rubber hose from the trailer completely, and am planning to connect it directly to the tank when I set up camp. That will give me more flexibility, as long as I make sure no one is tripping over the hose.
Old 07-31-2020, 03:39 PM   #4
Trailer: Trail Mite
I think this is the part I was looking for from the stove. Now I just need a quick connect adapter to connect to the female 3/8 flare fitting.
Sturgi-Safe RV Quick Connect LP Grill Hose (6 Foot) https://www.amazon.com/dp/B07SXSXTPD..._e8ijFbBEY60RR
Old 07-31-2020, 04:35 PM   #5
Trailer: Trail Mite
I think I solved part of the problem. This 4' hose with male quick connect adapter can connect to my stove. https://www.amazon.com/gp/product/B0...C63G3VB4R&th=1
Now I just need a female quick connect adapter that can connect to the female 3/8" flare connector on the flexible hose from the propane tank.
Old 08-01-2020, 04:19 PM   #6
Timber Wolf's Avatar
North Florida
Everything you need is available from Amazon. The only gas appliance IN my Scamp is a new Propex heater. Outside at the tank I have a quick connect for my propane Coleman stove or lantern.
Old 08-06-2020, 07:23 AM   #7
Trailer: Trail Mite
Thanks Timber Wolf, I did a bunch of searching and I think I found the parts I need!
For Sale: fiber stream custom custom dclayton NEW Fiberglass RV Classifieds | Buy, Sell, Trade 8 05-26-2020 01:52 PM
Connections to manufacturers Roy in TO General Chat 8 10-02-2008 03:00 AM
6 Volt Battery Connections VIDEO kevin61 Problem Solving | Owners Helping Owners 0 07-13-2008 04:28 PM
Gray water fittings and connections? Roy in TO Plumbing | Systems and Fixtures 4 06-02-2008 11:52 PM
Battery Connections dlehman Problem Solving | Owners Helping Owners 19 05-19-2007 09:19 AM
