Replacing a faucet - Fiberglass RV
Old 06-02-2021, 05:22 AM   #1
Trailer: Trillium 4500
Replacing a faucet
Hi everyone, we’d like to replace the faucet and was wondering can we install a hot/cold faucet or do we need to buy a cold water faucet only? We only have a cold water line. If it doesn’t matter what do you do with the second line? Thx!
Penelopeblue4500 is offline   Reply With Quote
Old 06-02-2021, 06:18 AM   #2
John in Michigan's Avatar
Trailer: 1979 Boler 1700
The Trillium 4500 was originally manufactured with two faucets: a hand water pump tap that drew water from the fresh water tank and a city water pressure tap. Each of the two taps used a single hole.
Because the sink is small and there is little space behind the sink AND the fiberglass countertop flexes, I would choose a small, single hole tap / faucet for city water, such as a bar faucet. The other consideration is that your grey water is drained outside the trailer into a container you provide. If the grey water container is small, or if you don't want to be frequently disposing of large, heavy quantities of grey water, then you'll want the water to flow at a low rate, and limit the amount of water used.
We chose a small single tap water filter type faucet for city water use.
Old 06-02-2021, 06:34 AM   #3
Thank you.
Old 06-02-2021, 10:22 AM   #4
Faucet
Block the tube on the left.
kayaker51 is offline   Reply With Quote
Old 06-03-2021, 11:31 AM   #5
Kenny Strong's Avatar
Trailer: 93 "Lil" Bigfoot 13.5'
Utah
I bought a faucet with a top turn on lever; at the camper supply.
You turn it left for one line input to come on right for another line. I have no hot water input line. one side goes to the water pump, and water tank. the other line is hooked to an outlet on the side of the trailer ( a factory installed city water inlet.)
City water pressure is controlled by pressure regulator I put on the hose connected to the city outlet in camp grounds.
I would not buy a fixture with 2 knobs.
My fixture has a spray head that pulls out; I bought the most powerful water pump. I don't know if the brand of fixture is inferior, it works so poorly. I haven't tried it with city water pressure.
I had the sink out when I put it in. Have put in other fixture with sink in place but very close working conditions
Later Kenny
Kenny Strong is offline   Reply With Quote
trillium
Replacing water lines and faucet- Scamp CarrieR Problem Solving | Owners Helping Owners 9 05-08-2016 03:22 PM
Need ideas replacing single faucet in Scamp!! stephbigs Plumbing | Systems and Fixtures 22 07-07-2013 01:43 PM
Faucet spits no more! Ruth C. Problem Solving | Owners Helping Owners 6 01-08-2006 01:53 PM
13' Boler - pump faucet Legacy Posts Problem Solving | Owners Helping Owners 4 06-18-2003 03:20 PM
Water pump/faucet repair Legacy Posts Care and Feeding of Molded Fiberglass Trailers 0 09-25-2002 09:10 PM
