Shower water usage - Page 3 - Fiberglass RV
Old 03-23-2019, 11:58 AM   #41
ibupnorth's Avatar
Trailer: 2018 Casita SD 17'
I humbly suggest the question be restated differently. Like how much water do YOU want to carry and how often do YOU want to dump the grey tank? (If you're a pirate like me then leave off the dumping grey tank part ------sometimes).
Sometimes I think we don't fully develop "common sense" because it is either outlawed, or at the very least, highly regulated. I'm in no way suggesting that the origninal question is not a good one. It's just that a suitable answer depends on many variables and regulations that don't always follow common sense. If you have ever backpacked or "dispersed" camped, it is generally acceptable practice to bury human waste in a 6 inch deep hole at least 200 feet from any water source. Some readers may be thinking, "How outrageous! So much much crap in that 6-inch deep hole so close to the water!!! This is not responsible at all!!!!!!" Interestingly, the distance between my 1000 gallon house septic tank and my well is about half that far. Doesn't make sense but I didn't make the rule. If you ask me, there's an interesting correlation between hole/tank size and water available and ability to move the water.
As I equate places where the water table is so high as to prevent burying waste or draining grey tanks in a hole to be like a swamp and unsuitable for camping, I would think most people are safe to dispose of their grey tanks in state/national forest lands where they are camping unless otherwise posted against such practice. Here's a quote from a National Forest website: "When camping in remote areas without toilet facilities, people should move away from streams, and dig small holes to serve as toilets and then cover them well. Gray water should be dispersed on the ground in a wide area, away from streams, and away from the campsite area" (1). Also read the Suggested Gray Water Dumping Guidelines at the link at the bottom (2). Hey, if it's good for backpackers and tent campers it's good for me too! Just common sense if you ask me.
Depending on the state you may find yourself in, shower water may be classified differently from the kitchen sink water allowing the shower water to be drained pretty much anywhere but the kitchen sink water must be disposed of the same as the black tank at a dump station. This sort of simulates using the outside shower (or washing a car) to run off naturally without the guilt associated with the grey tank dumping on the ground. Yup, you read it right. So break out that hack saw and cut that shower drain pipe so you can install a shutoff before the grey tank and tee off a water hose. DON'T use that prestine blue or white drinking water hose though. Anyway, I again suggest we use common sense in the matter.
Since an RV is generally considered a temporary residence when at a location other than a campground, we are natually conserving more water because of the hassle of getting more water too often --- at least while boondocking. So go ahead and take those Hollywood showers and don't worry about the amount of water commonly used. You'll run out of water soon anyway and then it won't matter. Just make sure you dump it out under where your exterior shower is. That's just good common sense.
(1) https://www.fs.usda.gov/detail/mnf/n...TELPRDB5066205
(2) https://www.rvtravel.com/more-on-the...the-gray-tank/
IBUPNORTH
ibupnorth is offline   Reply With Quote
Old 03-23-2019, 12:31 PM   #42
Trailer: Burro Wide Body 17ft.
Nebraska
We use a three gallon garden sprayer for showers, spraying sand or dirt off feet, quick hand clean, etc. Just set a dark colored sprayer in the hot sun. It will absorb heat and make the water pretty hot so be careful, you can add some cold water to it if needed. If you have shorts or swimsuit on, you can take a nice shower out side. With the spray wand, you can get two nice showers from a three gallon sprayer.
Pete J is offline   Reply With Quote
Old 03-24-2019, 06:57 PM   #43
Trailer: in the process of buying a Casita 17 Liberty Delux
Ohio
Water used in a shower
To measure, drain the gray tsk, leave the valve open and put a bucket under the drain to catch the shower water. Easy peasy.
Dave8850 is offline   Reply With Quote
Old 03-24-2019, 10:14 PM   #44
Trailer: 1985 13 ft U-Haul
Took 4 pages and the last post by Dave gets the job done easily and accurately . Lee
Lee Senn is offline   Reply With Quote
Old 03-24-2019, 10:44 PM   #45
John in Santa Cruz's Avatar
Mid Left Coast
my daughter is backpacking all summer, started a week ago at the Mexican border.... she had beautiful long silky brown hair, nearly down to her elbows.
her friends gave her a haircut before she left.
shampoo? what shampoo?
fantastic fan battery usage kayleigh0302 Problem Solving | Owners Helping Owners 15 07-19-2017 12:16 PM
Advice on using an inverter and Amp usage bicklebok Electrical | Charging, Systems, Solar and Generators 43 10-02-2012 04:25 AM
Propane usage (T off the trailer tank or take a spare tank) knighth001 Problem Solving | Owners Helping Owners 13 09-20-2012 06:37 AM
Fiberglass RV Pricing - Holding Value vs. Usage Depreciation Mitchell Money Matters 54 08-11-2009 08:30 PM
Propane usage khoa l General Chat 13 11-03-2008 10:07 PM
Copyright ©2000 - 2023, vBulletin Solutions Inc.
