toilet trim part - Fiberglass RV
Old 09-08-2020, 05:24 PM   #1
AC0GV's Avatar
Wisconsin
toilet trim part
My Scamp toilet (it may be a Sealand 711) has a cover on it to hide all the plumbing parts. That cover is open and falling off every time I stop. Is there a way to keep it on other that tape around the toilet? I see no clips or latches. Are they broken / missing?
Thanks
Old 09-09-2020, 10:35 AM   #2
Trailer: 2016 -13' Scamp
Massachusetts
I seem to remember a little piece of nylon string (fishline) on one side of the trim - and a small hole on the other side of the trim collar. I threaded the nylon string through the hole and that, alone, stopped the trim collar from opening while traveling.
That's not a real specific answer but it should get you started on the "fix".
herons is offline   Reply With Quote
Old 09-18-2020, 12:51 PM   #3
Trailer: 2017 Scamp 13D & 2016 Highlander
Iowa
I just took a picture of my 2017 Scamp toilet cover. There is a small flexible piece of clear plastic that is stretched between two small ears on the cover. It is probably 1/2" x 2". See picture. It does not show up on the parts list that I looked at. The other side of the cover uses the cover material as a living hinge.
GpaNed is offline   Reply With Quote
Old 09-19-2020, 10:08 AM   #4
AC0GV's Avatar
Wisconsin
Thanks to both of you.
Originally Posted by AC0GV View Post
My Scamp toilet (it may be a Sealand 711) has a cover on it to hide all the plumbing parts. That cover is open and falling off every time I stop. Is there a way to keep it on other that tape around the toilet?Thanks
Thanks to both of you. Mine had the clear piece of stretchy plastic with two holes. I could not get it re-hooked so I used a small Harbor Freight “O” ring and it looks like it will hold.
Old 09-19-2020, 10:43 AM   #5
Massachusetts
Any port in a storm! Glad you came up with a "fix". I know how annoying it can be to find that collar open while traveling.
Old 09-19-2020, 11:16 AM   #6
Iowa
I had the same problem with the strecthy plastic, it didn't seem to have enough distance between the holes to reattach. So I used a hot nail to melt a new hole and then was able to use it.
I will remember the O-ring idea in case I need it.
Burro Trim Lok and door trim/seal nomadicitch Problem Solving | Owners Helping Owners 2 01-19-2014 08:27 PM
Ice box part time, electric fridge part time? zoshia Problem Solving | Owners Helping Owners 8 05-17-2012 04:21 PM
Need a part for Aqua Magic III Toilet - Boler Stef_Dave Problem Solving | Owners Helping Owners 3 09-22-2011 07:39 PM
Burro trim, part number? AndyW Problem Solving | Owners Helping Owners 4 02-24-2006 07:50 AM
Copyright ©2000 - 2023, vBulletin Solutions Inc.
