Originally Posted by Iowa Dave
I like an adjustable regulator and have one with the filter on one end and a bib on the other end that a pressure gauge can show CG pressure or just a regular hose on it. I keep the pressure going to the camper at 40 PSI or below. I usually use two hoses the 25 goes to the area of my back bumper where I attach my filter and then a second short hose goes to the hookup on the trailer. In the picture , I happened to hook the filter to the regulator because the bib was high enough and water was close to the Eacape. Otherwise, I use a wrap of masking tape or black electrical tape to keep the filter on the bumper up out of the dirt etc. I’ve camped where pressure was 100 PSI with my regulator. Every water system is different and if a system is not looped where pressure is generally uniform throughout the system and instead the CG is on the end of the system, pressures can be high. Does a job on irrigation systems at times also. Laugh if you’d like, works for me. That’s a DCVA regulator assy to prevent backflow. Yes, I have stock in Continental Brass Company. YMMV
Iowa Dave
Hi: Iowa Dave... Being among the "Top brass" at my place I'm under a lot of "Pressure" too!!! Every system is different but I have learned not to use another regulator if there is one already on the CG. hose bib!!!
