Water heater has kidney stones - Page 2 - Fiberglass RV
Old 01-23-2021, 07:07 PM   #21
Trailer: Trailite
Wisconsin
You do NOT need to replace the rod unless it has been eaten away. They are sacrificial....meaning when they are chewed up, replace them. If not, re-use them.
David Prast is offline   Reply With Quote
Old 01-23-2021, 07:22 PM   #22
Trailer: Amerigo
Wisconsin
What the original poster found was maybe the remains of one or several previous anode rods.
bigangelman is offline   Reply With Quote
Old 01-23-2021, 07:51 PM   #23
Trailer: Trailite
Wisconsin
Possibly....but in my youth I worked on a residential water heater that had 6" of white gravel on the bottom of the tank. This was before the days of anode rods so it was strictly mineral deposits. I've seen it with both gas and electric water heaters. It is common. When you here rumbling noises from your water heater, it is due to an accumulation of the white granular mineral deposits. they act like a blanket of insulation on the bottom of the tank and with a gas fired water heater, it causes superheating at the bottom of the tank. This leads to porcelain lining failure which leads to rust followed by pin holes.
Old 01-23-2021, 07:52 PM   #24
Specifically, like this:
Old 01-25-2021, 12:21 AM   #25
Trailer: Currently Shopping
Montana
You can use a small portable softener unit to treat your water that you fill your tanks with or inline at your campground connection. The ion exchange units are the same type as home units, but without the automatic brine regeneration tank. You can run several hundred gallons of water through these units before you need to regenerate them. These will remove the hardness (calcium + magnesium) in exchange for increased sodium in the water. In most water it should remove over 90% of the scale forming cations and should get most of the iron and manganese too. I use an On-The-Go unit with a Culligan cartridge sediment pre-filter.
celcius232 is offline   Reply With Quote
Repairing fibreglass wear from stones Ventura Girl Care and Feeding of Molded Fiberglass Trailers 5 09-07-2020 06:43 AM
Tow vehicle has 4-way flat wiring and trailer has 7-way round boler girl Towing, Hitching, Axles and Running Gear 75 06-21-2020 02:45 PM
Atwood tankless water heater, has anyone oredered one? I did....... jcham1970 Modifications, Alterations and Updates 23 03-01-2014 06:37 PM
Who has "replaced the water heater with a outdoor camp shower unit? ShawnKK Modifications, Alterations and Updates 23 08-23-2013 08:40 PM
Copyright ©2000 - 2023, vBulletin Solutions Inc.
