07-01-2013, 10:33 PM
Water pressure regulator
Hello All,
Will be picking up my new Scamp 13' next month. The Scamp will have a sink, but not a toilet or shower. I was wondering if I will need a Water Pressure Regulator when hooking up to water at the campgrounds. I saw one at Cabellas a few days ago and hadn't even given it a thought until then. I would appreciate any ideas anyone has about this.
Thank you
07-01-2013, 10:42 PM
The water pressure regulator protects the plumbing in your trailer from being trashed by too high pressure. If you have a sink, I presume you have plumbing ( not always the case on this forum ).
It's cheap insurance.
07-01-2013, 10:44 PM
Always a good idea to use one. Pressure at campgrounds can vary greatly. Mine stays on my hose permanently.
Trailer: tp
water pressure reg
Originally Posted by Dave Harris
Hello All,
Thank you
Yes buy one and use it. It will save your pipes from blowing apart.
Chuck
07-01-2013, 10:50 PM
Thank you Chuck, Carol and Glenn,
They are cheap enough, Will pick up one and add it to my collection of supplies going to Backus.
07-02-2013, 04:37 AM
Don't buy the cheap plastic regulator. The brass kind is only a couple of bucks more. When the brass regulator I own quit working, it turned out it was the rubber hose washer... the screen was plugged. Cleaned it well and it's good to go.
07-02-2013, 06:15 AM
Glade Valley, North Carolina
You can also buy a brass one at Walmart in the camping/RV section.. However, some newer campgrounds may already have regulators on the water hookups. Better safe then sorry. Congrats David on the new Scamp and welcome to the forum.
07-02-2013, 08:37 AM
"Need" is a pretty strong word. With all the pex piping I expect it isn't needed. However, I agree with the others that it is cheap insurance. I've always used one the few times I've had that option.
08-26-2013, 09:26 PM
Trailer: 82 burro 13 "PookaBurro"
Does anyone know if any regulators are also backflow preventers (one way flow)? Or do I need a separate backflow preventer inline?
08-26-2013, 09:42 PM
The city water inlet on the trailer should have a one way flow regulator (backflow) built into it.
08-26-2013, 10:03 PM
Mine doesn't have a regulator or backflow. Just a short piece of pex going to the faucet.
The only times I've used city water there was a regulator already on the water tap.
08-26-2013, 10:14 PM
After I typed that Byron I realized that some of the older or cheaper city water connections may not have had a built in check valve. But even this pretty cheap one on e-bay claims to have a check valve.
08-26-2013, 10:36 PM
OLDER???
Older than what? Your Scamp is 14 years older than mine.
There's a difference in water systems. My city water connection goes directly to a faucet at the sink. The fresh water tank is not ever pressurized and I don't have a water heater, water pump, or shower. Pretty simple system. I do have a regulator/check valve. But I noticed that most of the campgrounds that have water hookups have a regulator/check valve attached to the their of the hookup. (water bib). If that's pretty much the standard a regulator/check valve might not be necessary. However it's pretty cheap insurance.
As for me I think I actually connected the city water 3 times in 8 years. I thinking I'm going to take the faucet out cause it seems always be the way. I can turn that into a paper towel holder.
08-26-2013, 10:39 PM
No Shower, no need for city water.
David,
Without a toilet and shower there's no need to connect to city water. Simply fill the fresh water tank. I have a trailer very much like yours. I don't use the city water connection.
You'll need to sanitize the fresh water tank as soon as you get it.
Enjoy.
08-26-2013, 11:19 PM
OLDER???
There's a difference in water systems. My city water connection goes directly to a faucet at the sink. The fresh water tank is not ever pressurized and I don't have a water heater, water pump, or shower. Pretty simple system. .
LOL yup my trailer is old but the CIty Water Connection is not original and it does have a check valve built into it as yours probable does if its the same as the one Scamp is currently selling on their website as I know that one does as well. Yup the piping is different on all the trailers based on options installed but if the trailer isnt to old & the water is going through a city water connection it probable has a check valve on it so no need to buy a separate one, which was my attempted point to the question asked.
08-27-2013, 06:52 AM
Most of the shore water connection points have a built in reverse flow preventer if only to prevent water going out when you are using an on-board pressure pump. In the same vein, few have a pressure regulator. I always attach an inline pressure regulator at the hose bib.\, before my hose.
08-27-2013, 08:54 AM
NW Wisconsin
Most of the campgrounds in my area have anti siphon (Backflow preventers ) at the sill cock ,because it is required by the State to prevent the possible contamination of potable water. The anti siphons at the campgrounds do not provide pressure regulation , at least in the ones I've seen .
