water tank hoses in U-haul 13 - Fiberglass RV
Old 08-20-2021, 06:47 AM   #1
Trailer: U-Haul CT-13
Iowa
Hi! According to the parts diagram, there are four hoses that lead from the water tank.
One goes to (or from) the low pressure fill device.
One goes to the faucet.
One goes to the drain.
The fourth goes to the outside access, but doesn't seem to connect to anything. Would I be correct in assuming this is a vent line?
Thanks in advance!
kombiguy is offline   Reply With Quote
Old 08-20-2021, 07:30 AM   #2
There is a city water connection in the panel on the left outside of the trailer. I had removed the water system from our CT so don't remember just exactly how it was plumbed. You can find the users guide in the document center here, no diagram, but it mentions that if there is city water (campground water hookup) available you can connect a garden hose at the forward connector in the panel. White colored RV hose should be used along with a pressure regulator and maybe a filter.
Old 08-22-2021, 12:02 AM   #3
Everywhere
That definitely sounds like a vent. In most cases there's a larger-diameter fill line and a smaller-diameter vent line.
Old 08-22-2021, 08:33 AM   #4
If it's from the top of the tank it must be a vent. The city water connection would not go to the tank, now that I think about it more.
u-haul
Propane hoses rubbing on tanks on my 17 Casita Komrade Modifications, Alterations and Updates 7 08-21-2021 12:42 PM
Propane Hoses Hold Cylinders All The Way Through Wreck Civilguy General Chat 30 12-07-2017 09:01 AM
New water tank and exterior tank fill "door" Treedles Modifications, Alterations and Updates 10 10-11-2013 10:38 AM
Regulator and hoses Quint362 Plumbing | Systems and Fixtures 10 03-13-2012 11:44 PM
Trouble adding water to a fresh water tank Dan Tracy Problem Solving | Owners Helping Owners 1 05-05-2008 08:11 PM
Copyright ©2000 - 2023, vBulletin Solutions Inc.
