When I got my '99
Burro I noticed that there wasn't much holding up the appliances! In fact the
fridge and the water heater were basically hanging on the
fiberglass. I have since remounted both. Here is what I did for the water heater. I have a water heater blanket coming and there is room to fit the blanket between the mount and the tank... I ordered one of those thin(5mm) foil backed blankets that I will cut to fit. The angle bracket locating the mount uses one existing hole in the floor, I'd rather have two of those metal braces on the sides, going into the plywood but the existing hole and I didn't remove the heater so getting a drill in there was a no go. BTW, I didn't want to over do it as this is a 20+ year old appliance that may be replaced with something different when it fails. Tell me what you guys think! Do you think this is ample support to travel without draining the heater?
