Originally Posted by barisad
I was told another reason to use antifreeze is that it keeps your seals lubricated. Especially the seal in the toilet.
As I understand it, there are two versions of products used as RV antifreeze.. Ethanol (alcohol) based, and Propylene Glycol based. The latter does provide some lubrication and protection for the seals, but the former will actually degrade the seals. Now to add confusion, my Walmart SuperTech branded AF lists these ingredients:
Water, Ethyl Alcohol, Propylene Glycol, dye and Dipotassium Phosphate.
IIRC ingredient listings are supposed to be in order from most to least, so the SuperTech AF is mostly water, then mostly Ethyl Alcohol, then Propylene Glycol, etc.. But in what percentage I do not know, so how good (or bad) it is for the plumbing I also dont know. Some shops claim to use only Propylene Glycol. But my spectrum analyzer is broken so I would not be able to verify that claim on my trailer.
