For Sale: 125Ah Smart Lithium Iron Phosphate Battery, New in box, free shipping - Fiberglass RV
RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 05-08-2020, 05:09 PM   #1
Trailer: aliner
Smart 125ah e On Lithium Iron Phosphate LFP Battery New in box.
Many batteries, like this one, have electronic protection. Even with electronic protections fires or worse occur when electronics fail or cells short from damage, manufacturing or abuse. to make this the safest available battery even if damaged.
Unlike most batteries, Thorough information is collected and available including cell by cell voltage and event records that few others have. By easily monitoring to avoid under 20 percent charge, lifespan can be substantially increased from 2000 to 8000 discharge cycles.
Key information including are . All other info is easily seen and understood. Also along with cell by cell voltages to greatly extend lifespan. NO extra displays to buy or install!
can be used with existing lead acid battery charging systems with reduced to 100Ah capacity. Charging upgrade recommended within a few years to get full 125Ah capacity.
allows removability and powering of external devices via included 15A accessary plugs and 60A terminals. Typically used to power Trade booths, parties, trolling motors, etc.
with SAFE, MONITORED and EASY focus. Smarter MPPT solar controller provides thorough bluetooth monitoring RV electrical load use, all Solar info along with 30 day history. Smarter Converter decreases its 50Amp charge rate as battery nears 100 percent then drops to 13.6vdc to avoid battery overcharging and RV electronics stress . Complete system is EASY and flexible to install 2 parts . If you change campers, it is EASY to move system to new camper. Pics included.
View this ad at Fiberglass Classifieds - 125Ah Smart Lithium Iron Phosphate Battery, New in box, free...
MelH is offline   Reply With Quote
Old 05-08-2020, 07:14 PM   #2
Trailer: aliner
FOR UNKNOWN REASON, THE PREVIOUS POSTING DROPPED A LOT OF BOLDED TEXT WHICH CAUSES IT TO LOOK VERY STRANGE AND LOOSE A LOT OF MEANING. I'VE REPOSTED IT BELOW WITHOUT BOLDED TEXT. Please accept my apologies and THANKS to those that pointed it out!
MelH
Description: Smart 125ah e On Lithium Iron Phosphate LFP Battery completely equipped for safety, monitoring, ease of use, and extended lifespan. New in box. FREE SHIPPING.
SAFE: Many batteries, like this one, have electronic protection. Even with electronic protections fires or worse occur when electronics fail or cells short from damage, manufacturing or abuse. This e On LFP battery includes both electronic and chemical protections to make this the safest available battery even if damaged.
MONITORED: Unlike most batteries, no extra monitoring must be bought, installed, wired and manually recalibrated, Thorough information is collected and available including cell by cell voltage and event records that few others have. By easily monitoring to avoid under 20 percent charge, lifespan can be substantially increased from 2000 to 8000 discharge cycles.
EASY: Key information including Percent Charge, Volts, Amps, Temperature., Cycles used are presented to your phone using Bluetooth both with numbers and graphics. All other info is easily seen and understood. Also includes Automatic percent charge recalibration and automatic cell by cell balancing along with cell by cell voltages to greatly extend lifespan. NO extra displays to buy or install!
Battery can be used with existing lead acid battery charging systems with reduced to 100Ah capacity. Charging upgrade recommended within a few years to get full 125Ah capacity.
ALSO AVAILABLE:
POWER PACK battery enclosure allows removability and powering of external devices via included 15A accessary plugs and 60A terminals. Typically used to power Trade booths, parties, trolling motors, etc.
Complete SMARTER POWER SYSTEM with SAFE, MONITORED and EASY focus. Smarter MPPT solar controller provides thorough bluetooth monitoring RV electrical load use, all Solar info along with 30 day history. Smarter Converter decreases its 50Amp charge rate as battery nears 100 percent then drops to 13.6vdc to avoid battery overcharging and RV electronics stress . Complete system is EASY and flexible to install 2 parts . If you change campers, it is EASY to move system to new camper. Pics included.
Contact me if you would like more info. Thorough description, specs, testing results, and other information is available on my BoondockingPower company website.
For Sale: Smart 125Ah Lithium Iron Phosphate battery, New in box. MelH NEW Fiberglass RV Classifieds | Buy, Sell, Trade 0 02-01-2020 11:43 AM
Lithium battery in Lil Snoozy Air Doug Electrical | Charging, Systems, Solar and Generators 64 12-23-2019 08:30 PM
RV Lithium Battery honda03842 General Chat 20 07-16-2015 03:47 PM
Lodge Cast Iron Dutch Oven, Griswold Waffle iron & more Gigi Classified Archives 2 06-23-2008 05:44 PM
