SUPER RARE 1972 Hunter Compact Jr. Vintage Camp Trailer 1000 Very
Light For Towing with Small Vehicle.Absolutely beautiful blank slate, original components,
fiberglass shell, frame, hitch, bumper, back door, stove, icebox, drawers.
Ready for your design, your custom curtains, your custom colors, perhaps even your custom layout!
These originally came with an expanded metal pattern vinyl liner, this specific trailer does NOT have that original liner, but instead it has blue indoor outdoor carpeting glued to the inside. This would be easy to remove or easy to incorporate with your decor.
Check your vehicles towing capacity, if it s less than 2000 pounds you can still haul this trailer!
This is one of the few trailers that you could hook onto a four wheeler and pull up the trail!!
With so many original components and the beautiful
fiberglass shell that is always waterproof, this tiny RV Will be the talk of your neighborhood and campground.
I pulled it at 80 miles an hour when I brought it home from 150 miles away. It tows like a dream.
It has the original hitch, with safety chains and the large 7 pin modern connector. The
lights worked intermittently, which tells me that I had a grounding problem from the truck to the trailer, could be fixed with WD40 spray to make the hitch connection more surface rust free.
This is an Idaho trailer, and in Idaho it is high desert so we do not have rust problems or salted roads so the frame is as solid as new.
This trailer has new
tires. There is no spare wheel, and no spare tire. I understand the wheels and
tires are very easy to find at Walmart. There is no
propane tank, or bracket for the tank.
The cabinet doors are in the trailer, just not installed. They are there with the hinges in place.
Also, someone cut a vent in the Fiberglas top, a small one and they did a great job but it is not original, as far as I know but would be an easy Fiberglas fix. The rising center pop up top is drooping as normal for an original, so when the Fiberglas repair is done on the vent, additional glas should be added to bolster the top to be more solidly curved up. The top is not leaking at all.
The canvas in the pop up top is shredded enough that it needs replaced, but the snaps and hardware are all there and I believe are original.
Please let me know if you have any questions or need any more information.
I have a
title and a bill of sale that match the tag and the
VIN number.
For local pick up in Albion, Idaho
However, I drive all over Idaho, eastern Oregon, northern Nevada, northern Utah and most of Wyoming so delivery MAY be an option but I CANNOT deliver it for free. We can work this out depending on your location, but I m not very interested in driving beyond these areas.
View this ad at Fiberglass Classifieds -
1972 HunterCompactJr. CompactJr.
