Wanted: 3 way fridge - Fiberglass RV
Old 04-26-2021, 04:59 PM   #1
3 way fridge
Looking for a 3 way fridge for my 1973 Boler. max height 25inches, max depth 19 inches, max with 19 inches
View this ad at Fiberglass Classifieds - 3 way fridge
hannahzaharik is offline   Reply With Quote
Old 04-26-2021, 05:26 PM   #2
David Tilston's Avatar
I recommend an RM211. Lots of them out there.
Old 04-27-2021, 04:45 PM   #3
3 way is not worth it. The 12V sucks your battery down in no time at all. Even while driving it will not keep up with the depletion on the battery. We found out the hard way when we accidentallly hit the 12V button and drove all morning with one on 12V. At lunch it was over 45 degrees in the fridge and everything was getting warm. Our trailer battery was dead. Put fridge on porpane and by evening the fridge was cold and the battery recharged. So if you can get just a propane/120V get it. We never use the 12V except to go from a campground to the gas station if only on 12V for a few minutes so we don't have to turn off the fridge before getting to the pumps. Then we fuel up and pull out to the edge and put the fridge on propane. Never fuel up with any appliance on propane. Make sure all are turned off. A spark can cause an explosion of gas fumes. So a sparker on the fridge could cause a fire if there are gas fumes present.
Old 04-27-2021, 05:05 PM   #4
Governor Bud's Avatar
Trailer: 2005 Bigfoot 21
Free State of New Hampshire
fridge alternative
we replaced with 75$ walmart dorm fridge
we use 110; in campgrounds and jackery powerpack on road
good solution for us
Governor Bud is offline   Reply With Quote
Old 04-28-2021, 07:42 AM   #5
One, most of the smallest (Boler-size) RV absorption fridges are 3-way, so you get DC function whether you can use it or not. Two, while I agree many tow vehicles are not capable of running a fridge on DC while towing, it’s not a given, and in some cases it can be remedied with heavier wiring. Our other RV- a Class B- runs the fridge fine on DC and recharges the batteries while driving. It’s harder with towed RVs due to smaller alternators and longer wire runs, but not impossible.
If not, then yes, towing with the fridge on propane is possible. In addition to refueling, it also has to be turned off for some longer tunnels and bridges.
For shorter trips, just pre-freeze some food or drinks and toss them in the fridge while you drive. As long as the fridge is pre-cooled and you don’t open the door, that should give you several hours with the fridge off.
Old 04-28-2021, 09:52 AM   #6
I agree with Jon. 3 way, (12VDC, 120VAC, Propane) is just what is commonly available. You don't have to use the 12VDC option.
I would never install a dorm fridge, unless you know that you will always camp where there is power, like in a camp ground. However, if you think you may, one day, camp in more remote locations, where no power is provided. There are only two practical refrigerator options. One is an absorption fridge, like a three way, that can use propane. The other is a 12VDC compressor fridge and solar power. Typically both of these options can take advantage of an external 120VAC source.
Old 04-28-2021, 10:13 AM   #7
You don't have to be in remote locations to camp without power, either. Many nice public campgrounds don't have hookups, and even when when hookups are available, the unimproved sites are often cheaper and more natural, less like a trailer park.
Old 04-28-2021, 10:47 AM   #8
Alex Adams's Avatar
Trailer: 1979 Boler B1300
New Hampshire
Here is what I am planning on putting inside my boler 13 footer:
https://www.novakool.com/r3000-1
The cutout is 24.5" high by 19.25" wide by 16.5" deep. It only uses 2.5 amps when running so it is very efficient. I have solar for charging my battery so this should be no problem for me, not sure what you planned on doing.
Can a 2-way fridge become a 3-way fridge? Rob Carmody Problem Solving | Owners Helping Owners 13 06-24-2016 10:54 AM
3-Way Fridge vs AC DC Fridge? Krista Modifications, Alterations and Updates 44 04-14-2016 06:34 PM
7 way plug to 4 way plug back to 7 way plug immrbill Problem Solving | Owners Helping Owners 3 08-10-2015 11:08 AM
2 way compressor fridge vs 3 way propane aimeelightsey General Chat 9 05-20-2011 05:56 PM
Way Way up North Al V Rallies, Get-togethers, Molded Meets (Archive) 23 06-23-2006 02:30 PM
