For Sale: ANDERSON WEIGHT DISTRIBUTION HITCH 4" RISE Model 3324 - Washington - Fiberglass RV
Old 09-20-2022, 05:20 PM   #1
ANDERSON WEIGHT DISTRIBUTION HITCH 4" RISE/or Drop Anderson Model 3324 lightly used lt; 3,000 miles.
Can handle up to 10,000 GTWR but I recommend 7500 lb max for a margin of safety
Sells new from Casita factory for 489 plus shipping
We used it to tow our 17' Casita Spirit Deluxe, We changed tow vehicle for our Casita and the new TV has anti sway/weight distribution built in so our loss is your gain.
Shipping is extra will only charge what it costs. estimated to be 65 to 150 depending on distance from Zip 98360
Anderson WDH eliminated the need for sway bars. The design of the Andersen Weight Distribution Hitch eliminates the sway and bounce in your trailer, using the interconnected motion dampening chains and sway control ball housing system. Each WD Hitch Kit includes: an adjustable steel rack, grease free ball and silent friction cone, anti say plate, 2 motion dampening tension chains and urethane springs, two sets of tongue brackets.
Check the Anderson model number 3324 to ensure compatibility with your RV
  • Unparalleled Sway Control that self adjusts
  • So quiet you won't even know it's there!
  • Patented True Motion Dampening system drastically reduces bounce
  • Weighs under 60lbs!
  • 2" ball included no extras to buy
  • One pin removal from tow vehicle
  • Grease free system ball and coupler move as one
  • Easy install no pry bars needed!
  • Optional 8" drop/rise adjustable shank available Anderson part 3351
  • Doubles as standard ball mount for towing without weight distribution
  • The smoothest ride around I can vouch for that
  • No problem backing up unlike many other weight distribution hitches
  • 10,000 lbs GTWR 1,400 lbs tongue weight
  • Lifetime Warranty limited
View this ad at Fiberglass Classifieds - ANDERSON WEIGHT DISTRIBUTION HITCH 4" RISE Model 3324 - W...
LarryOrganicFarm is offline   Reply With Quote
Old 09-20-2022, 06:28 PM   #2
Raspy's Avatar
Trailer: Xplore X22
Smith Valley, Nevada
Larry, Not sure why you posted this. But just in case you are asking about them, in my opinion, the Anderson hitch is a ridiculous design. And the Anderson Company has had questionable responses to problems. The hitches are hard to hook up and do take some getting used to. The only place they sort of make sense is on Oliver trailers and that is because they fit the Oliver without cutting any fiberglass. And it only makes sense then for tow vehicles that cannot handle a tongue weight of more than 500 lbs. I cannot think of any other benefit to the Anderson hitch.
Old 09-20-2022, 08:22 PM   #3
Trailer: 21' Escape
Which tow vehicle and camper combination did you use the Andersen hitch?
Tom and Linda
ATHiker is offline   Reply With Quote
Old 09-20-2022, 09:07 PM   #4
Raspy's Avatar
Trailer: Xplore X22
One came with my Oliver but I never used it. I watched Anderson's responses and problems for years on the Oliver forum, and I have a good friend who uses one because his F150 has to have a WDH with a tongue weight over 500 lbs. He has an Anderson because of that Ford rule and having an Oliver. I looked closely at the design and decided it was not for me. I towed my Oliver with a heavier truck and had absolutely no need for a WDH, especially with the very stable Oliver LE2, but I was interested in the design, so I checked it out.
It applies its force in a different direction than a conventional WDH, and seems to be strictly for highway use with very limited uneven road surfaces. The ball and the anti-sway clutch were problems for a long time. Some stability control warnings were triggered on Fords and Anderson's response was to tell people to turn off the Ford stability control. Oliver LE2 trailers don't need sway control, but the Anderson has it. There were a lot of sway control clutch failures and Anderson replaced them under warranty. First they said the ball did not need lubrication, but when they started wearing severely, Anderson said they needed lubrication. That's fine, but it shows the product had extreme forces and was not fully perfected.
Another issue, that had nothing to do with the hitch, but said a lot about Anderson's owner, was when he carved his name in a National Monument at Arches NP. His excuse was that he loved his family and wanted to express it. The outrage was pretty severe.
My only suggestion is that if you need a WDH, look around and see what is available. See how they connect to the tongue and how you hook them up. The conventional design with spring bars has been around a long time and works. If you have an Oliver, the Anderson is the one that mounts with no fiberglass cutting.
Old 09-29-2022, 11:36 PM   #5
Steve Outlaw's Avatar
Trailer: Oliver
Don't forget that when he got caught and the officials were on their way, his love for his family was so great that he sent a teenage son back to their vehicle to hide/swap-out their license plate.
Steve and Tali - Dogs: Reacher and Rocky and our beloved Storm, Maggie and Lucy (waiting at the Rainbow Bridge)
2022 Silverado High Country 3500HD Diesel 4x4
Steve Outlaw is offline   Reply With Quote
Old 09-30-2022, 01:05 PM   #6
Trailer: Escape 21C sold Bigfoot on order
Ohio
Yep as a NPS retired employee, I would never do business with this company.
oldwave is offline   Reply With Quote
Anderson Weight Distribution Hitch Gish Towing, Hitching, Axles and Running Gear 21 06-28-2020 05:59 PM
Help Anderson hitch with 2016 4Runner UpstateCasitaFolks Towing, Hitching, Axles and Running Gear 14 06-06-2019 10:12 PM
is my weight distribution hitch worth the tongue weight and effort. beachcamper54 Towing, Hitching, Axles and Running Gear 24 01-25-2014 12:41 PM
