Wanted: Bag awning - Fiberglass RV
RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 02-02-2020, 03:31 PM   #1
Trailer: 2010 Little Joe / 2010 2 Dr Jeep Wrangler
Bag awning
Looking for a small bag awning something that can be mounted amp; left on trailer while traveling
Not sure exactly the length but my trailer cabin is only 10 long so anything from 8 to 10 wide...and something that extends out approx the same.... I m doing a modification to a small trailer
Thanks in advance
View this ad at Fiberglass Classifieds - Bag awning
Old 02-02-2020, 03:58 PM   #2
Trailer: 2013Escape 21
Iowa
Awnings
Start with Flamma USA. Iíve seen several adapted to campers
Iowa Dave
Iowa Dave is offline   Reply With Quote
Old 02-02-2020, 05:04 PM   #3
Trailer: 2008 Casita 17 SD
Marti's Vintage Trailer Awnings
I have one made by her, and it is top notch. She will also custom make it to any size and from any pattern/colors you like. Mostly free slide-in awnings, but I like them because they don't take up any space and weigh almost nothing for storage.
Old 02-02-2020, 06:35 PM   #4
Bag awning
Bag awnings are designed to hang on a vertical sidewall. When mounted on a curved surface they sometimes have a tendency to collect water inside when closed. It depends on the shape of your trailer. With the more rounded styles, you may find it gets wet inside when towing in the rain and you may need to remove it for long-term storage.
Shademaker is the most common brand, owned by Dometic if Iím not mistaken.
Marti makes rope and pole awnings, which have to be removed for towing.
Fiamma makes case awnings. Do they also make bag awnings?
Old 02-02-2020, 09:24 PM   #5
We had a Shademaker bag awning on our Uhaul CT13. It did get water in the bag if left on the trailer. I don't know if it had much to do with the curve of the trailer, maybe the stitching didn't seal good. Also if left on the trailer while traveling the awning would flip upside down. I would only put the awning on the trailer when using it in a campsite. Kind of defeated the idea of it. I know a Scamp 13 owner that had the same problems. Also if you get the 8 foot awning it is only available with the cheap twist lock poles. Above 8 foot length the good poles and rafters are available. It was a OK awning, but not the best.
Bag Awning vs. Regular Awning Pamela S. Problem Solving | Owners Helping Owners 7 02-22-2020 06:20 AM
Can the bag awning be longer than the awning rail? Jeremey Modifications, Alterations and Updates 2 08-30-2018 01:45 PM
Bag awning on Scamp awning mounts jcassady Problem Solving | Owners Helping Owners 2 10-06-2015 07:10 PM
8' bag awning on a 7' awning rail--pics? NEWFISHER Problem Solving | Owners Helping Owners 12 04-14-2014 09:57 PM
Bag Awning Advice Legacy Posts Problem Solving | Owners Helping Owners 5 06-05-2003 09:23 PM
» Trailer Showcase
the boler
Wildwood
Lily
Wpuvy
