I have two Venturer brake controllers New amp; Used
for sale.
One unit is new in seals package human proof = 35
One that is not in package = 10
Both are in perfect condition. After having electric
brakes on a trailer you will never go back...its great!
Im located in Cincinnati Ohio
Let me know if you have any questions
From Website
Increases brake power based on gain setting and sensitivity adjustment
Operates 2 6 trailer
brakes at a time 1 3 axles
No internal moving parts and no leveling required
LED indicator lengthens as controller applies power
Mounts anywhere in the vehicle, at any angle
Product description:
It takes a lot of power to stop a moving trailer, especially when that trailer is hauling a heavy load. On RVs, flatbeds, livestock trailers and many other oversize haulers, manufacturers typically install trailer
brakes to assist the tow vehicle in bringing such a massive amount of
weight to a halt. But it takes more than a good set of brakes to make quick, efficient stops. It takes precision and the right amount of control. The Venturer is a compact, easy to set up time based brake controller. It can be mounted at any angle and has an automatic power level adjustment feature. It can operate one to three axles at a time, meaning two to six brakes, and has an LED display for monitoring brake pressure. Venturer is compatible with anti lock brakes, cruise control and comes with a limited lifetime warranty. All CURT brake controls are designed to work with quick plugs so that they can readily plug into your vehicle's original equipment socket. They also include a mounting bracket and hardware for easy installation. A brake controller should be mounted somewhere on the dash of your vehicle, and we recommend putting it below the steering wheel, either on the right or left side of the steering column. This way the control will not block your view when driving, but it will remain accessible and visible when adjustment is needed.
View this ad at Fiberglass Classifieds -
CURT VENTURER Brake Controllers
