We are selling our
Trillium 4500 travel trailer to move on to a larger
fiberglass camper
Escape 17A . Our
Trillium is the deluxe edition 4500 with an extra louvered window in the kitchen, a privacy window in the door, and upper shelving around the entire inside as well as drawers under the seats in the dinette and along the bottom of the bunk. The frame has been reinforced and lifted. We have had many great trips over the past 6 years after upgrading from a
Trillium 1300 when we had our second child in 2017. I built custom bunk beds that easily hold kids or small adults and also upgraded just about every mechanical component leaving the cosmetic side about as original as possible. Check out the long list of upgrades and additions below. Tongue
weight is just under 300 lbs and it tows like a dream with both our Honda Pilot and our Chevy Silverado. The main dinette folds flat into a 50 x 77 bed and the bunks measure 25 x 70 each and hold inflatable sleeping pads perfectly. The hubs and electric
brakes are only a couple years old and the bearings were serviced this summer.
- Redarc DC DC lithium charger that charges the lithium battery while driving via the 7 pin round connection from tow vehicle see picture
- New 3,500 pound axle with recently replaced leaf springs and new Monroe shock absorbers for super smooth dampened ride this setup is amazing for towing on highways and back roads
- Recently added electric brakes
- Newer 13" radial trailer tires with low mileage
- Added LED marker lights, new waterproof LED brake/signal lights underneath original Trillium lenses, plus added an LED 3rd Brake Light mounted above rear window see photos
- New manual 1,000 lbs Norco Industries tongue jack with foot pad
- New tow chains with heavy duty clips for connection to tow vehicle
- Trailer box customized with BlueSea 3 way shutoff switch that allows switching between DC DC charger, camper power, or both on or all off.
- Upgraded most of the 12V wiring throughout camper. You can switch between DC power with solar panel charging or shore power through a converter that runs all DC devices including fridge
- Custom awning pole tube mounted to front tongue see pics
- Custom spare wheel mount with single propane tank holder behind front tongue box
- Custom Sunbrella awning with side shades and three quick release poles
- Custom heavy duty, reinforced 2 bike hitch receiver with support brace welded to frame of camper see pics of bike rack mounted
- 100 watt Renogy briefcase style solar panel with 30 feet of high end cable and proper fuse connections
- SAE solar connection port added beneath detachable shore power connection on outside of camper
- The shore power is through a detachable plug for use of an extension cord connection to camper for AC shore power
- Rebuilt stock AC/DC converter with new fuses, new proper gauge wires and waterproof connections plus removed original converter and installed an external SAE connection to supply DC power using an external AC/DC 15 amp converter
- Installed custom bunk beds original bottom and top cushion/bunk included with camper sale
- All lighting original but upgraded to warm white LED bulbs throughout
- Added frosted privacy glass to window in door
- New Propane regulator
- New SunQueen 100 Amp hour Lithium battery
- New 7 pin trailer cable along with new waterproof breakout box mounted under tongue
- New custom wood floor finished in eco friendly polyurethane
- New 12 V fridge, model is Truck Fridge TF49; it's super efficient and the fridge can run on battery for 2 3 days without running down battery. Plus added 3" insulation board around entire fridge except at heat vent in back
- New Renogy MPPT solar controller with Bluetooth connection to connect to app for monitoring from device
View this ad at Fiberglass Classifieds -
1977 Trillium 4500 deluxe - Massachusetts
