Well, our spring/summer/fall camping did not go according toplan due to reasons beside Covid. Therefore, we are seriously looking to sell our 2008 Bigfoot25B25RQ. It s something we dearly have enjoyed, working on, and camping in. It has only been used for camping,not travel. We are the 2nd owners of this unit. Just my wife and Ienjoying the unit. I am gauging the market here to determine purchasing interestin the 25RQ? I can tell you that thefloor plan is exactly as you see in all the other models of that year andforward. We didn t change anything there. This does not have the external extendedframe storage area up front. As with any usedRV, there are some aesthetic items that may need addressing. We are not goingto address these as we believe a new owner can make the changes due totheir preferences and likes. They are asfollows: 1 exterior decals are crackedand need removed, replaced, painted, or just left as is depending on the futureowner s preference. 2 the wallpaperaround the
windows has crinkled likely due to changes in temperatures andtrailer movement . This can easily beaddressed with a number of options. 3 Originallinoleum floor that has yellowed in areas below throw rugs. Lastly, there is not an
awning. We didn t careto have one preferring a canopy instead.
Equipment and Improvements:
Valterra Holding Tank Valve amp;Termination Cap with Hose Connector
6 gallon water heater with Hott Rod WaterHeater Conversion Kit provides electric or
propane hot water option
Electric Tongue Jack with cabin isolatorswitch
EAZ
Weight Distribution with Anti Sway amp; Hitch I have never used the anti sway amp; it is not mounted
BAL Wheel Locking Chock/stabilizer 1
Fridge fans internal and external providesexcellent circulation. External are thermostatically controlled with isolatorswitch
Accurite
Fridge amp; Freezer MonitorSystem
Lippert Radius Triple Folding Step 2years old
Exterior Entry Motion Detector
Light
5 4 plus spare Goodyear ST225/75R 15/10 EnduranceTires Low miles, 3 years old
15" 80LB Allied 870 Rims for"E" rated
Tires Conversion
4 Vinyl Wheel Coverings
Custom Holding Tank Cross Bar Supports removeable
EZE Rv Gutter System
Timkin Wheel Bearings
2 Kyocera 130 Watt ea. roof mounted
solar panels
Rogue Controller with remote monitor
2 Lifeline AGM batteries 6 volt 220 AHeach
Xantrex 600 ProWatt SW Pure Sine WaveInverter
LED ligthing through out with overhead galleylighting
Articulating Arm for small flat screentelevision
Small shelf for Blu Ray Player
Oxygenics Shower Head
Nakamichi AM FM Radio with USB/Bluetoothinputs amp; DVD Sound and Jensen speakers
Screen Door Cross Bar Holder
Front and Rear Large Insulative WindowCoverings
Oven/3 burner stove
Microwave can be removed. I have doors ifcabinet storage is preferred
Double stainless steel sink
Stove Top Wood Cutting Board
Overhead LED Galley
Lights
Coleman Mach 3 11K BTU A/C 2 years old
Custom Fabric seat covers
Camco Olympian Wave 3 Catalytic Heater
3 45 Heated Gallon Holding Tanks
San T Flush Built in Black Tank Rinse withcheck valve
Under sink water filtration with faucet
Holding Tank Monitors Work Well
porcelein toilet
Roll Away Shower Door
Winterizing Valves
Shurflo water pump
Winterizing By Pass
2 skylights 1 main cabin, other in shower
Continental spare tire kit with optional spare tiremount located on rear underside of frame
2 Fantastic Fans over bed 3 speed,reversible and thermostatically controlled and in bath
Dual 30LB
propane tanks with auto changeregulator
Battery disconnect isolator switch
Honeywell Digital Thermostat
Thermal
Windows
Ladder and Carrier Rack
View this ad at Fiberglass Classifieds -
2008 Bigfoot 25B25RQ Anniversary
