SOLD: 2014 Parkliner Parkliner - Florida - Fiberglass RV
Old 07-11-2023, 08:33 PM   #1
Trailer: Park Liner
Hi all,
Our beloved 2014 Parkliner trailer is up for sale. I am the second owner. This trailer is in optimal condition, well taken care and maintained. Everything works as it should. It is very spacious and constructed with quality in mind. The reason for the sale is because we do not want to continue paying storage fees.
The trailer has 3 new tires included spare , new Dexter Axle Hub and Drum Kit For 3,500 lb. axle w/EZ Lube Cap and new Dexter 3,500 lb Axle NEV R Adjust Electric Brake, two new batteries see date in pics . Also installed and battery switch of and exhaust fans on AC cabinet for improved performance. I also painted most of the frame last year with POR 15, polished, waxed it and treated rubber seals. Included in the sale there is an anti sway bar and the hitch 4 inch drop .
We are located in South Florida, Clean FL title in hand. Sale is in cash at a local bank.
These are the descriptions and specs.
GVWR:
Interior Length: 12
Interior Height: 6 5
Interior Width: 6 10
Real glass windows all the way around, top hinged for open in the rain. Astro foil insulation covered with special fuzzy wall lining
Welded Rectangular Tube steel Chassis, coated with rust inhibiting paint
3500 Lb. Rubber Torsion Axle
Electric Brakes w/automatic adjustment
Break Away Switch, Tongue Jack
2 BAL Leveling/stabilizing Jacks in the rear
Standard Hitch weight: Approx. 275 lbs.
Overall Length: 15
Hitch Height to top of 2 ball [on your car]: 18 inches
Tire Size: ST205/75/R14 on powder coated steel rims
2300 lbs. dry weight
Approximate tongue weight: 220 lbs.
Overall Height Clearance: 8 9
Overall Length: 15
Overall width: 6 10
Two peace fiberglass body.
Queen size bed that converts to a dinette for 4
Side dinette that converts to a couch/chaise lounge
Firm comfortable cushions throughout
Top hinged windows that you can open in the rain, screens included.
Laminated table tops, kitchen grade over lightweight plywood
21 linear feet of overhead storage space with doors to make it useful
Closet w/coat rod and chair/stuff straps for guns, rods, skis, and other long things
Hat rack over entry door
Stainless sink w/light overhead/electric water pump
Large full depth flatware/utensil drawer under stove
Stainless dual burner propane range
Microwave over sink
Shower stall 6 3 high, no bump bend forward too
Marine grade flush toilet SeaLand 8100 series
15 gal. freshwater tank, additional 12 gal. freshwater tank, 30 gal. waste tank
Shower pump switch next to faucet
45 Amp power converter w/integral 120VAC breaker and 12VDC fuse panel
Dual Batteries Group 24
Fantastic ceiling vent/fan over the queen bed
3 GFCI receptacles in living space, plus one outside near door
Electric water pump and switch 12 volt
Dual LP Tanks w/auto changeover valve,
3 way Fridge runs on propane, 12 VDC, and 120 VAC
6 gal Propane or propane electric Water Heater
30 gal. waste water tank
6 gal. prpane electric Water Heater
Bath sink
All pressure side plumbing enclosed in trailer
Valve on water heater for easy winterizing
Outdoor water faucet
Spare Tire
Fire Extinguisher
Propane Leak Detector
Fire/CO Alarm
Clothes Rod in closet for hanging clothes
Chair straps in closet for chairs amp; stuff
Vinyl flooring
Refrigerator 1.9 CUFT LP/120VAC/12VDC
Furnace w/thermostat, electronic ignition
Cover/Food tray for range
Tile behind galley
Fold out galley extension
12VDC receptacle
LED Lighting
Additional 120VAC receptacle
12 V DC outlet
Table that enables the queen bed/dinette to become a half table or foldaway crescent shaped couch
Corner shelf/chaise lounge/seat back for dinette
Fiama Awning
Styled Aluminum Wheels w/radial tires
Keyed Deadbolt Entry Lock
Screen Door
HD TV and trays to hold DVD
View this ad at Fiberglass Classifieds - 2014 Parkliner Parkliner - Florida
Allenvazquez is offline   Reply With Quote
SOLD: 2014 Parkliner ParkLiner - North Carolina RussellG Classified Archives 0 04-25-2022 07:11 PM
Florida Egg Rally in Florida! Sherritini General Chat 13 12-22-2017 07:14 PM
