SOLD: 2019 Escape FifthWheel5.0TA Delux - Tennessee - Fiberglass RV
Old 02-11-2025, 09:41 PM   #1
Trailer: Escape
2019 Escape 5.0 TA
For Sale: 37,500
We are the original owners and have enjoyed this fiberglass fifth wheel camper over the past several summers. We have used it at local lakeside campgrounds each summer. This camper has been well maintained and stored under cover. We are buying a larger fifth wheel for longer campground visits. We will miss this very well built camper. We have had zero problems or need for any repairs. This camper always gets compliments from folks at gas stations, rest stops, and campgrounds.
The lightweight Anderson Ultimate Adapter system and yellow Fort Knox hitch lockbox go with the camper.
The Escape 5.0 is 21ft 2in plus attached aluminum generator box. It is easily towed with a mid size truck. It offers a full wet bath, separate sleeping and living areas, as well as an extra high ceiling for a spacious feel. The Escape 5.0 targets trucks with a minimum 5 ft 5 in bed length and suitable payload/tow capacity.
The aerodynamic design, tandem axle and low center of gravity makes for better road stability, fuel economy, and decreased wind resistance. The one piece fiberglass trailer construction creates an incredibly stiff and smooth structure to last a lifetime.
This Escape 5.0 TA has a permanent two person queen size bed in the raised area at the front of the trailer and came with an upgraded U shaped four person dinette that converts to a two person bed in the rear of the trailer.
Specs:
Exterior Length: 21 ft 2 in
Exterior Height: 9 ft 11.5 in that includes a 3 in optional factory installed frame lift.
Exterior Width: 7 ft 4 in
Fresh Water Capacity: 28 Gallons
Black Water Capacity: 30 Gallons
Grey Water Capacity: 28 Gallons
Liquid Propane Gas Capacity 2 X 20 lbs
Hitch Weight: 646 lbs
Axle Weight: 3,264 lbs
Total Dry Weight: 3,910 lbs
GVWR 5500 lbs
View this ad at Fiberglass Classifieds - 2019 Escape FifthWheel5.0TA Delux - Tennessee
SamM is offline   Reply With Quote
WA | 2019, May 17-19: Maryhill in May 2019 paulw Rallies, Get-togethers, Molded Meets (Archive) 31 05-21-2019 10:48 AM
AZ | 2019, Feb 4-10: Quartzsite Gathering 2019 Greg A Rallies, Get-togethers, Molded Meets (Archive) 137 05-15-2019 06:26 PM
