SOLD
2021 13
Scamp Standard with Bath Layout 2. 54" Bed model. Original and only owners. This was our first trailer and served well and pulled behind our Subaru Outback. We are non smokers and no pets. We don t wear shoes in the trailer. Currently winterized.
Features include:
54" Bed converts to dinette
Brown Cushions
Air Conditioner with Heat Strip
Maxx Air Fan
Shower with toilet
6gl water heater operating on gas/120v electric
1.9 Cu Ft
Refrigerator Gas/120v/12v
2 burner stove
Vinyl floor
Gas
Furnace
Group 24
Battery
Wheel on Jack
Screen door
Storage Cover
Propane Tank
Electric
Brakes
Extras:
Wheel lock nuts with tool to take off lock nuts
Wheel lock
Hitch lock
Chain saver attached to jack Keeps chains/7pin plug off the ground
Replaced
Scamp safety chains with 24 5000lb safety chains that clip on tow vehicle Have original chains as well
Weight:
I believe the trailer
weight to be 1850lbs unloaded with a hitch
weight around 250lbs full propane/battery
The trailer has a GVWR of 2200lbs, please make sure your vehicle can tow up to that weight.
Please be sure that you have 7 pin wiring outlet tested , a 2 hitch ball 18 height at top of ball , brake controller that is functioning for your tow vehicle. You will need this to tow the trailer safely.
Items to address:
Small crack at top of kitchen sink. Does not cause issue, but cosmetic.
Scamp sent replacement sink to us, but have not installed it. Shown in pictures.
Need to seal around door frame. I noticed some water had got into closet from the door frame after washing trailer with hose. I dried it quickly and kept damp rid and and eva dry unit beside the spot. I see no water damage or stains. I would suggest using a sealant around door frame. Only noticed when washing trailer and not in rain. Slight gap between the door frame and
fiberglass at the bottom not enough sealant . 2021 is the first year of the Scamp door redesign I believe, instead of the curve door before.
Firm on price.
View this ad at Fiberglass Classifieds -
2021 Scamp 13 Standard Layout 2 Big Bed
