It is time to part with our professionally renovated 1995
Burro. We have a clear Washingon State
Title. We purchased this in April of 2014 from a lovely older couple in Sequim, Washington. Over the span of three years, we had it professionally restored. Old School Trailer Works completed the majority of the
renovation. Due to our daughter s passion for performing in Musical Theatre, we have only taken our
Burro on two trips in the past six years, once to Yellowstone and once to the Olympic Peninsula.
We have always kept our
Burro covered in our carport. We have an inspection receipt from Poulsbo RV dated 7/29/2020, all systems are working correctly, and the
battery was replaced. She is fully ready for many new adventures!
The Burro is a lightweight two fiberglass shell design that avoids the rot and
weight issues of many other campers of this size. Fiberglass forms the seats, closet, and kitchenette. We just had it weighed on a licensed scale. It is 1,460 pounds with 5 gallons of water in the 10 gallon tank and a full
propane tank. All accessories shown in the images were also in the camper at the time of
weighing. This camper has an electric braking system, which makes it even easier to tow, be sure to check your owner s manual to determine how many pounds you can tow if your camper has
brakes. You will need a 2 inch ball hitch and a 7 pin connector.
Sale includes camper cover, hitch lock, and wheel lock.
- Exterior Dimensions 13' Long, 6' 5" Wide, and 7' 4" High.
- Interior Dimensions are 10' Long, 6' 4" Wide, and 6' 2" High
- The double bed is 46"x76" and the bunks are each 24"x76".
Frame Repaired 2 Locations
Sanded and Repainted Frame
New
Propane Tank Holder
Modified
Battery Location
Added New Regulator/ Flex Hose
Body Removed, Reinforced Underneath the Body
Added Additional Layer of Marine Grade Plywood to the Inside of the Floor
Additional Structural Reinforcement at the Frame Locations
New Molding and Door Gasket
Replaced Door Strike; Exterior Fasteners and Hinges
Removed, Cleaned, Re Sealed
Windows
Powdercoated Frame and Added New Lexan to Front Window Cover
Prepped Exterior for
Paint
Installed New
Solar Panel
Installed New Power Vent Fan
Installed Power Converter and Wiring
Exterior
Light and Escutcheon Replacement
New Tow Wiring
New
Light Wiring as Needed
Installed Trailer
Brakes
Installed New Hub/Brake Drum with New Bearings
New Mag Wheels and
Tires
Removed Existing Flooring
Installed New Vinyl Flooring with Metal Cove
New Painted Cabinet Doors
New Birch Ply Clear Coat Finish Shelves, Hatches
Cleaned and Restored Icebox; Added Additional Insulation
Built New Truss Style Table Top
Installed New Three Burner Cooktop with New Hood Vent
Replaced and Cleaned Bunk Hinge Area
All New Foam Cushions
Upholstered Seat Cushions in Genuine Cowhide with Fabric on Bottom
Upholstered Back Cushions in Performance Velvet
New High Quality Automotive
Paint
Door Reinforcement
Clear Rock Guard Applied over the
Paint on the Front of the Burro
Custom Storage Boxes
New Headliner
Installed Vinyl Blinds
View this ad at Fiberglass Classifieds -
SOLD Burro 13
