Lightweight Construction double wall w/
fiberglass insulation. Approx.
Weight 1500 pounds. Hitch
weight 125 pounds. Interior Width 7 feet 3 inches. Interior Height 6 feet 3 inches. Easy to clean
fiberglass interior. Rivet less exterior construction. Large tinted acrylic
windows, are openable with built in screens. 2 Roof Vents, 1 powered w/ 3 speed reversible, thermostat controlled Fan Tastic 14 fan. Lots of storage areas, plus closet.
Three burner
propane range. Under counter propane/electric Dometic
refrigerator. Double bowl stainless steel sink. Stand by hand water pump at kitchen sink. 17 gallon fresh water tank. Propane/110vac 6 Gal Suburban Water Heater. Full size porcelain toilet by Sea/Land. Front dinette with removable table. Custom mattress 5" thick, 5' wide, 78" long very comfortable, generous sleeping area can be easily converted into a dinette
110vac 20A service cord,
Propane tank, 20 lb , Manual tongue jack w/wheel, 3500 lb Torsion
axle suspension w/ 3 inch riser for added ground clearance, Electric
Brakes, Fire extinguisher, Spare tire with cover, Gravel shield front window, Rear mounted stabilizer jacks w/ front jack stands
Misc pots, pan and cookware, Water press regulator, 25' fresh water hose, Elect amp; Plumbing hookup components.
With a dry
weight just under 1500 lb and 125 lb tongue, you can take this little camper on the road with almost any small SUV. Plus, it is
light enough to move round your driveway by hand on the included jack wheel, and fits in a single standard parking space.
Unlike some other
fiberglass campers, Burros have both an exterior and interior fiberglass shell, separated by a layer of aluminum backed insulation, making them stronger, better insulated, and less prone to condensation than many other fiberglass designs. The curved gelcoat interior reflects the
light around and creates a very open, airy feeling, rather than the claustrophobic, stuffy feel that plagues many small campers. The fiberglass walls are easy to wipe down and clean after the weekend adventure.
Trailer has a flushable Sea Land marine toilet, though no official bathroom. The shower always leaked like a sieve so we just "bucket washed". New wood on interior components, nice solid core Oak plywood table, closet doors, and under seat storage covers. Custom curtains provide privacy. The skylight roof vent has been rebuilt with a 12vdc, 3 speed, reversible, thermostatic controlled 14 vent fan. Dometic
fridge has no freezer compartment, and is propane/electric, Kitchen sink has added hand pump in case electric pump fails.
LED lights have been installed to reduce
electrical load during off grid camping.
The Burro's cute retro styling turns heads and gets thumbs up wherever it goes. The door latch was rebuilt to be more secure than it was originally.
Tires are good having been kept off the trailer and stored inside for the last 5 yrs. Bearings and
axle are in great shape.
Axle was upgraded to a 3500 axle and raised 3 to allow for greater ground clearance, has electric
brakes. New caster wheel for tongue jack. Running
lights all work and are LED, trailer
electrical connector is a standard 7 connector plug.
Exterior gel coat has seen a lot of sun weathering and could use a
paint job, suggest a marine type epoxy
paint. Window and door seals are dry and stiff and need replaced.
Windows do leak and the seal replacement would be a first thing to look after. We've investigated replacing the whole
windows and have info on sources of supply.
This camper is a ton of fun, and we're sad to see it go, built for many more years of adventure, and we know whoever buys it will love it as much as we have!
View this ad at Fiberglass Classifieds -
Burro 17' Wide Body As manufactured
