-   Forum Admin, News & Announcements (https://www.fiberglassrv.com/forums/f65/)
-   -   Time and date (https://www.fiberglassrv.com/forums/f65/time-and-date-24198.html)
JOHN PAUL EVANS 01-04-2006 04:38 PM
For some reason the time and date is not in correct on the postings. I assume it is something with the server that needs to be coordinated with some US time zone such as Eastern standard time. No big issue, but when someone is working on the server they could correct it. https://www.fiberglassrv.com/board/st...lt/confuse.gif
Donna D. 01-04-2006 05:41 PM
John, it's displaying correctly for me. Please check your personal board settings:
My Controls (Across from your Login name)
Options (in the Left Nav Bar)
Edit Board Settings
Check the TIME setting particularly..I think the default is "Casablanca" ???
Mine is set to Pacific Time...which is correct for me.
And I have the box checked for "Auto Correct DST" (which is for Daylight Savings Time.)
Let us know if you continue to have problems.
https://www.fiberglassrv.com/board/st.../default/4.gif
Frederick L. Simson 01-04-2006 08:17 PM
Check the TIME setting particularly..I think the default is [b]"Casablanca" ???
https://www.fiberglassrv.com/board/st...lt/confuse.gif I always thought that the default was Greenwich Mean Time, which is London, England. https://www.fiberglassrv.com/board/st...efault/shg.gif
Bigfoot Mike 01-04-2006 09:02 PM
That is what I thought too. This new software has this time glitch. I haven’t found a fix or work around yet. Many of us just set our personal time adjustments to handle the offset.
https://www.fiberglassrv.com/board/st...default/29.gif
My current problem, that is taking my time, is the album software. https://www.fiberglassrv.com/board/st...fault/ohmy.gif I have an upgrade but not sure it is the best solution. So I am testing several other options.
https://www.fiberglassrv.com/board/st...default/35.gif
Donna D. 01-04-2006 09:18 PM
1 Attachment(s)
It is Frederick...kinda, sorta..see the attachment, this is the default members need to change to their own time zone.
Frederick L. Simson 01-04-2006 11:51 PM
Ah, all those places line up on the same longitude. Casablanca is merely alphabetacally impatient. https://www.fiberglassrv.com/board/st...ault/okrra.gif
Bigfoot Mike 01-05-2006 11:27 AM
https://www.fiberglassrv.com/board/st...ult/banana.gif
A friend has given me some insight as to how to set the new software Native Time. The correct time has been set on the Forum Software.
Go to your “My Controls” >> Options >> Board Settings >> (Set your time offset)
“My Controls” = upper right
“Options” = Left NavBar , down about 2/3
https://www.fiberglassrv.com/board/st...ult/banana.gif https://www.fiberglassrv.com/board/st...ult/banana.gif https://www.fiberglassrv.com/board/st...ult/banana.gif
