-   -   Canadians Who Bought the 54 Watt Solar Panels at Cosco (https://www.fiberglassrv.com/forums/f95/canadians-who-bought-the-54-watt-solar-panels-at-cosco-25758.html)
Paddy Morris 05-25-2006 07:03 PM
So how did we go about hooking up the three panels? Mine will require me to cut wires, splice them, figure out + - any pics of the Canadian wiring?? Arrrrrrrrrgelite https://www.fiberglassrv.com/board/st...efault/shg.gif https://www.fiberglassrv.com/board/st...default/35.gif
ttmatson 05-25-2006 08:35 PM
I "PMed" (is that a word https://www.fiberglassrv.com/board/st...efault/l31.gif ) - I have a PDF install that is VERY DETAILED with Diagrams, etc - TOO LARGE to upload here - let me know - - -
Also "if" the board wants it for the document center let me know how to get it to you https://www.fiberglassrv.com/board/st...default/94.gif
t & t
Paddy Morris 05-26-2006 04:23 AM
t & t
That would be great, I emailed you as well, tks Paddy. https://www.fiberglassrv.com/board/st...lt/bowdown.gif
Paddy Morris 05-26-2006 10:00 AM
Doh! more diagrams https://www.fiberglassrv.com/board/st...default/OH.gif This isn't quite what I wanted, or needed, I know all that, I need to see what people DID with the COSCO set up. This is a lot of very good information though, thank you, Paddy
Paddy Morris 05-26-2006 02:06 PM
Update for Case #12009 - "54 watt coleman solar kit from Cosco"
>Hello Pat,
>Thank you for using our products.
>Please provide us with your full mailing address and phone number and we
>would be more than happy to send the missing harness (available late May)
>at no charge.
>Thank you for your patience.
>Also, if you wish to splice the wires, we recommend splicing before the
>connector's end without removing the connector, in this way the harness may
>still be used once received.
>A system diagram may be found through our website at:
>https://www.icpsolar.com/4105/system_setup.asp
>Simply connect all solar panels together (+) to (+), and (-) to (-) though
>splicing or when the harness is received.
>Also, the kit does not include wiring from the controller to the battery.
>We recommend using 14AWG stranded wire and installing only a few feet from
>the battery.
>Sincerely,
>Anthony @ ICP Technical Support
>Welcome to the ICP Store, Let Our Power Give You Freedom!
>www.solarcharger.com
>In the meantime, have you registered for our newsletter at
>www.icpsolar.com? This online periodical gives you up to date information
>about solar in general, new products, and even helpful suggestions to help
>you maximize the benefits of the solar solution from ICP that you have
>purchased.
>At ICP, we aim to provide our customers with the best possible care in the
>industry. If you feel at any time that you are not getting the best
>possible service, please do not hesitate to let us know and we’ll have
>someone from our Customer Service management contact you directly.
>Click here to update the Case online, or reply to this e-mail
>Message History
Well this seems promising https://www.fiberglassrv.com/board/st...ault/aplas.gif https://www.fiberglassrv.com/board/st...ult/banana.gif https://www.fiberglassrv.com/board/st...ault/okrra.gif
Paddy Morris 05-26-2006 03:14 PM
Very Promising
Update for Case #12069 - "Wiring Harness for CL3600"
Hello Pat,
Thank you the information, and your feedback.
It has been forwarded to our shipping department who will promptly send once available.
Sincerely,
