-   -   Front gelcoat finish! (https://www.fiberglassrv.com/forums/f91/front-gelcoat-finish-48891.html)
Nomad1 10-16-2011 12:48 PM
Hi! I'm Rey, new member on this forum yet have many years trailering in a metal/stick unit. I am about to purchase a new Bigfoot 25RB for full timing/boondocking. Should I be concerned with the road hazard damage to the front lower part of the trailer getting the gelcoat damaged/pierced? I am familiar that if the gelcoat is damaged, this will affect the integrity of the fiberglass. Has anyone taken steps to eliminate this situation? I have in the past used flaps on the rear of the tv, but I found that over the long terms exposure to road grime and moisture, rust set in more quickly. Would applying a coating to the front lower part of the tt be a good solution? :)
Greg H 10-16-2011 12:59 PM
Spray on bed liner, you can do it yourself or you can have it done professionally and the pros can color match your paint.
Donna D. 10-16-2011 01:56 PM
1 Attachment(s)
Or you can use Grizzly Grip (among other types) and do it yourself: Grizzly Grip
check out the colors!
