-   Camp Cooking, Food & Recipes (https://www.fiberglassrv.com/forums/f58/)
-   -   Boiling in Zip Lock Bags (https://www.fiberglassrv.com/forums/f58/boiling-in-zip-lock-bags-52610.html)
J.S.Lahm 06-19-2012 12:49 PM
:omy I wanted to cook eggs, in Zip Lock plastic bags, in boling water, on an up coming camping trip but ran into conflicting info regarding the safety issue. SO i called the Zip Lock people who said DO NOT DO THAT, That is enough for me, will find some alternative. Just wanted to share. Don't want to be feeding my kids, grand kids and that one adorable great grand something that isn't 100% A. O.K. :nope
Thomas G. 06-19-2012 12:52 PM
How about these or oven bags?
Amazon.com: PanSaver EZ Clean Multi-Use Cooking Bags Slow Cooker Liners: Kitchen & Dining
Mike Magee 06-19-2012 12:56 PM
I think that plastics can release harmful chemicals when exposed to heat. They even say not to leave plastic bottles of water in a hot environment like car or trailer.
Boiling eggs in the shell inside a plastic bag seems less likely to impart chemicals into the egg, but perhaps the shell is still somewhat porous. Best to err on the side of safety and health.
It seems like one would have to still place the eggs (bag or no bag) in water to boil; I can't imagine just a plastic bag full of eggs and water, placed over an open fire or on the grill, without the bag melting. So I'm wondering what purpose the bag would play?
J.S.Lahm 06-19-2012 01:07 PM
Tom, They are 4 liners for 6$, getting pretty expensive but at least safe. Will have to see how many people we need to feed or if we can combine the same kinds of omlets in one bag - I mean make 6 ham, cheese, onion omlets in one bag and share them out. May work. Thank you very much.
fusedlight 06-19-2012 01:08 PM
Not to point out the obvious... but they have this thing called a "pot" that you boil water in. Put water in pot. Put eggs in water. Heat. Or am I missing something?
steve dunham 06-19-2012 01:10 PM
Boil in the bag
We make boil in the bag three egg omelets when camping. Put the eggs , meat, vegetables and cheese in a ziplock bag , boil for 16 minutes and enjoy
I do not know which is less healthy the omelet or the bag ?
Thomas G. 06-19-2012 01:35 PM
My point was that they make bags specifically for cooking in - also called oven bags. The link was an example, not a recommendation. :)
David B. 06-19-2012 01:56 PM
boiling in ziplock bags.
We have been camping since the 1970's and have been making meals up at home, then freeze them in "Seal-A-Meal" bags. These act as "ice" in the cooler to keep other things cold. We simply boil water in a pot, place the seal-a-meal bag in the water, and your meals (ie scrambled eggs with sausage and cheese, or meat loaf, potatoes ... etc ) ready to eat. You then have the hot water necessary to wash dishes or kids with.
Happy Trails To You
Roy in TO 06-19-2012 02:02 PM
Bags & Rolls - Seal-a-MealŪ Vacuum Sealer Products
"Our multi-layer storage bags are specially designed to protect food from freezer burn. Choose from the 8" and 11" bag roll assortment to make custom-sized bags or use pre-cut quart and gallon size bags. All of our bags are safe for microwave or boil-in-the-bag heating. "
theresa p 06-19-2012 04:35 PM
an oncologist that i work with has been emphatically saying for many years not to heat plastic--either by boiling or by using the microwave....due to the noxious and poisonous chemicals that are released when any plastic is heated up.
i figure i'll listen to an oncologist...instead of seeking his services after i disregard his preachings.
jen b 06-19-2012 04:41 PM
I feel like I already throw away enough plastic in my life that I can at least skip cooking inside it, too. The idea of a single-use product that lasts forever is a little bit insane. But that's just me. I don't mind cleaning a pan after cooking.
bec 06-19-2012 04:45 PM
The other thing that it might be wise to consider avoiding is Teflon-cooking , not only does it not taste as good as when using pots or pans with a ceramic lining ( which is also non-stick - easy clean ), but it is advisable to not have a "canary "in the same area as cooking with teflon !
J.S.Lahm 06-19-2012 05:31 PM
WoW! Love all the replys, many interesting opinions. After reading all this and a good think--- I think I am just going to keep making omlets in my good old cast iron skillet, the one my mom started house keeping in...(remember this campout is to celebrate my 70th so this is an old skillet) I understand the novety of putting your own egg(s) in your own bag, adding the ingredients you want and dropping it in the boiling water BUT we'll do it my way..that's another advantage of being the old girl. bless you all..
Lynn Musgrave 06-19-2012 08:13 PM
Originally Posted by Thomas G. (Post 315864)
I have used these bags in my slow cooker,they do make clean easy when camping.The DOWN side ,that I have found, is that it takes Longer to cook with them. Example being...I like to cook a big Pot Roast in my slow cooker when camping ,so I thought this bag would be great for camping,veggies got done just fine...but the meat took almost twice as long to cook. My DD has used a dutch Oven liner and she says it takes longer for things to cook in the DO when she uses liners.
Mike Magee 06-19-2012 09:56 PM
Yup, just add a little bacon grease to your skillet first. Good eatin'. ;)
Bobbie Mayer 06-19-2012 10:05 PM
First of all, ziploc bags are made of Low density polyethylene, so the only thing they will release is ethylene, and then only if they are heated hotter than the temp of boiling water. Not a problem. I suspect the manufacturer just doesn't want the liability of saying it is safe to cook in them so they say it isn't.
Second, something you do once or twice a year on a camping trip is not something I'd worry about. If it had a slight risk, and you did it 365 days a year, then you worry.
Third, the smoke from your charcoal or wood fire is far more hazardous and so is the bacon.
IMHO... cook your eggs in the bags and don't sweat it.
One time I called the number on the side of some kind of food package to ask what would happen if I reused the plastic pan the food came in. The person I got admitted it was perfectly safe, they just say don't reuse it as some idiot will reuse it until it starts to fall apart, get burned, and sue. I suspect this is the same kind of reasoning.
Normedina 10-04-2012 12:56 PM
I made that mistake! My daughter had just given me 2 beautiful canaries, set the cage down on the kitchen table (by the big sliding window) to hear them singing while I made breakfast and I wasnt even done with the first egg when my grandkids noticed that one was already dead and the other one was twitching at the bottom of the cage. No one told me!
Gina D. 10-13-2012 03:54 PM
I have no microwave in my rig. I thaw solidly frozen meats (And other frozen items) by pouring boiling or near boiling water over it in a ziplock.
I let the bag float in the water for about 5 mins for an average sized serving and it thaws without cooking. I hate that with a microwave.
Passive aggressive thawing I call it :-)
hotfishtacos 10-13-2012 07:08 PM
What??!!
That was a good one!....:loltu
Carol H 10-13-2012 07:54 PM
Originally Posted by Bobbie Mayer (Post 316040)
First of all, ziploc bags are made of Low density polyethylene, so the only thing they will release is ethylene, and then only if they are heated hotter than the temp of boiling water. Not a problem. I suspect the manufacturer just doesn't want the liability of saying it is safe to cook in them so they say it isn't..
Actually according to Livestrong.org in a write up titled "What are the Dangers of Boiling Foods In Plastic Bags" they say "Ziplock brand bags have a softening point of 195 degrees, which means they would melt at boiling point, 212 degrees"
Under a section titled Chemical Leaching it reads "When plastic is boiled, the chemicals used to produce it can leach into the food being prepared due to a high temperature. Common chemicals in plastic include BPA and phthalates. Harvard Medical School says that high-fat foods are especially susceptible. NDSU adds that some plastic bags will leach toxic fumes from the ink, glue and recycled materials used in making them."
