-   -   New converter (https://www.fiberglassrv.com/forums/f95/new-converter-59205.html)
JimVerse 06-24-2013 10:49 AM
New converter
I'm replacing the converter on a viking pop up. I am able to keep the 110 volt distribution panel. The new converter directions show the + wire running from the converter to the 12 volt fuse strip and then to the battery. There are 2 open fuses in this strip both 15 amp. Can I wire to the battery from this fuse or should I run from the converter directly to the battery with an inline fuse? What gauge wiring?
Darwin Maring 06-24-2013 11:25 AM
A fuse at the converter protects the wire between the converter and the battery. Should there be a short in the wire to ground, the fuse at the converter would trip. no fuse at the converter and the short, the wire could get red hot and start a fire.
Same applies to the inline fuse at the battery that will trip on that end should there be a short between the battery and the converter and/or ground.
I would fuse both. Nothing smaller than 12 Gauge wiring. 10 gauge is better.
Steve L. 06-24-2013 11:58 AM
I don't know much about pop ups, this being a fiberglass travel trailer site after all, but in my Casita I believe the 12vDC positive from the converter goes to a thermal breaker on the side of the battery compartment before going into the battery.
I wouldn't wire the battery to one of the individual DC fuses. But, as I said, I have no clue about popups.
