-   -   ParkLiner wiring (https://www.fiberglassrv.com/forums/f95/parkliner-wiring-65525.html)
frank_a 07-29-2014 06:16 AM
ParkLiner wiring
Are all the lights in these ParkLiners 12V only? I need to figure out where to hook up a volt meter!
Frank
cpaharley2008 07-29-2014 06:28 AM
I use the plug in type NEEWERŪ Mini LED Display Digital Car Volt Meter 12V/24V Vehicle Voltage Gauge - Voltage Testers - Amazon.com
also now available with USB https://www.amazon.com/DROK-Cigarette...meter+with+usb
frank_a 07-29-2014 06:57 AM
That's great, but I do not have either a 12V plug or USB connection in my trailer!
So I'm back to the same question: where is 12V wiring in my ParkLiner that I can hook to for anything 12V? I think all my interior lights are 12V, but am not positive. I don't know how this stuff works!
Frank
Huck 07-29-2014 07:10 AM
Frank
All the lights are 12v. No 120v lights in the trailer.
I had ParkLiner install 1 12v outlet and I installed another myself. This is what you need to buy.
Find the wiring going to a light. Easiest to get to is the light over the small table. Then you split the wires and add the 12v cigarette lighter socket.
Not the best picture, but you can where there are 2 wires coming in and each is split to 2 wires. Then 1 pair rewires the light and the other pair go to the socket.
https://www.fiberglassrv.com/attachme...3f916f258f.jpg
frank_a 07-29-2014 07:26 AM
That is exactly what I needed to know! Thanks Huck. I am now dangerous...
Frank
