-   -   Upper kitchenette cabinet supports (https://www.fiberglassrv.com/forums/f55/upper-kitchenette-cabinet-supports-65731.html)
morgynm 08-10-2014 11:32 AM
Where do I put the supports I bought for the upper cabinet in the kitchenette?
I've seen pictures with two on the left side, one on the left side, one on the left side and one in the middle back, one in the middle back. I bought two wooden rail spindles ($2 at our local ReStore!) to use but have no idea if I need both.
Morgyn
1981 13' Boler
Nova Scotia
Jon in AZ 08-11-2014 08:43 AM
One metal support in the center back was the original Boler set-up, I believe. That said, seems like any of the other arrangements would work, too. Two on the left would likely give the best support (closest to center of trailer). Two side-by-side could also become an attachment point for bins, paper towel holder, etc...
If the support has been AWOL for a while, the roof may already have some sag. If that's the case you could post a question asking other Boler owners to measure the distance from the front left corner of the upper cabinet straight down to the counter. I have read where others used a jack to apply pressure to the ceiling (gently!) to restore the original height when reinstalling the supports.
morgynm 08-11-2014 03:07 PM
Thanks for the info! I never noticed that the left hand end of the kitchenette was in the middle! I measured the space between the upper and lower last night but forgot to write it down. I do remember (because it surprised me) that it was exactly on the inch though. It might have been 24" or maybe 27".
Morgyn
1981 13' Boler
Nova Scotia
